Old 09-19-2010, 04:40 PM
rutman is on a distinguished road
combination machine - eierlegende wollmilchsaue
I would like folks' opinions on a combination machine I'm considering building:
a vertical axis lathe (the part spins about a vertical axis) with an
x-y-z bed. As a lathe the xyz bed
moves the cutting tool. As a mill or drill the lathe headstock
holds the bit as in a regular mill or drill.
In this way I avoid having to rotate big sections of machine about.
The goal is a reasonable lathe+mill+drill combination machine that deosnt need much reconfiguration other than swapping parts/bits from the headstock
and parts/tools from the xyz bed.
Old 09-22-2010, 02:01 AM
Algirdas's Avatar
Algirdas is on a distinguished road
it is done already. See Okuma VTM or Okuma MacTurn sries machine tool
Lathe/Mill Combination jdmay SprutCAM 0 08-18-2010 09:51 AM
combination of the nextengine and mircroscribe? dalianharley 3D Scanning 5 01-21-2010 01:06 PM
combination keys mohammad reza Fanuc 3 08-24-2009 01:13 AM
Best combination lathe dismal General CNC (Mill and Lathe) Control Software (NC) 0 05-02-2008 05:49 PM
Combination 4 Axis router Lathe wjfiles DIY-CNC Router Table Machines 3 04-16-2007 06:08 PM
