Results 1 to 6 of 6
Thread: Newb Question: Difference Between 40 Taper spindle and a 50 taper spindle
    Sep 2010
    U.S.A.
    Just from reading what people type on here I can figure out that a 50 taper spindle is more suited to do heavy cutting. I just wanna know why. What are the physical differences between a 50 and 40 taper spindle? Is a 50 taper spindle just more robust and rigid then a 40 taper spindle? Also are there any other advantages besides heavy cutting that a 50 has over a 40 taper spindle. Sorry if my question does not make complete 100% sense. The machine shop I use to work at taught me everything about programming and set-up so I never needed to know about the specifications of machines.
    Jul 2007
    Size, the taper angles are the same but the diameter is larger: see http://www.parlec.com/pages/bt_taper_specifications
    and http://www.tools-n-gizmos.com/specs/Tapers.html
    bob
    Sep 2010
    U.S.A.
    So that means that tool holders would need to be bigger for a 50 taper then a 40 taper. Ahh I see. So the fact that its larger in diameter makes it better for heavy cutting?
    Dec 2009
    Hmm, seems like it, because of more surface area.
    Oct 2005
    spindle RPMs are (usually) higher with smaller tapers
    Mar 2006
    50 taper machines usually (almost always) have heavier, larger spindles and bearings. Also, slower spindle speeds. This more robust combination results in heavier cutting capability and the ability to employ larger tools. eg. larger dia. face mills.
    Dick Z
    DZASTR
    1. 40 taper spindle bargain (?)
      By H.O in forum General Metal Working Machines
      Last Post: 05-23-2009, 10:23 AM
    2. CAT-30 versus R8 spindle taper
      By NitroNutz in forum Industrial Hobbies (Support forum)
      Last Post: 03-23-2009, 10:03 PM
    3. Has anyone got the 30-taper spindle?
      By digits in forum Tormach Personal CNC Mill
      Last Post: 07-23-2008, 10:17 PM
    4. NST 30 spindle taper...what fits this?
      By Preston E in forum General Metal Working Machines
      Last Post: 01-20-2008, 02:50 PM
    5. spindle taper explanation
      By jwallace in forum Benchtop Machines
      Last Post: 08-16-2007, 07:01 AM
