Old 09-16-2010, 03:43 AM
LikuiD is on a distinguished road
Help choosing suitable milling machine
Hi all,
We own a small workshop in Cairo, Egypt that's based entirely on conventional machines. Lately, we've faced some difficulties doing some parts using our conventional machines, and had to turn down a few jobs.
So we're thinking of investing in a CNC milling machine to use with these types of jobs.
Generally we work with 1-mm thick Low-carbon steel, and sometimes aluminum.
We have already determined all of our machine specifications, but couldn't determine the suitable horsepower that would be needed for the spindle motor.
So could anybody please suggested how much hP would at least be needed for our applications ?
Also, if we buy a used machine with a max. RPM of 6,000, would that be ok ?
Thanks !
Old 09-16-2010, 06:41 AM
An old "rule of thumb": 1 cubic inch of steel per minute requires 1 horsepower. That is for mild steel, not hardened tool steel. LOL
Dick Z
DZASTR
Old 09-16-2010, 11:18 AM
Algirdas's Avatar
Algirdas is on a distinguished road
Are You sure, You need milling technology? Isn't it metal sheet?
Old 09-16-2010, 03:37 PM
Dick Z
Thanks for the tip Richard, I think mild steel & low carbon steel are one and the same, aren't they ?
It's not suitable for sheet metal forming machines, the workpiece consists of a hollow elliptical shape, that has a thickness of 1mm. The milling has to be done on 1 side of the ellipse only.
Choosing the right milling machine for making RF coils for MRI aot PCB milling 4 06-27-2009 08:06 PM
Is this machine suitable ball99 CNC Plasma and Waterjet Machines 0 08-17-2008 08:04 PM
Is the Syil / Sieg X3 suitable for climb milling? Ed from NY Syil Products 19 08-30-2006 10:10 AM
Need a suitable machine Moesian Mechanical Calculations/Engineering Design 0 08-14-2005 11:49 AM
Are Linear bearing setups suitable for Milling Machines??????. Moondog General Metal Working Machines 8 11-02-2004 08:33 AM
