Old 09-13-2010, 02:47 PM
pit-bull is on a distinguished road
Hardinge VMC 600II Power Up Problem
Hardinge VMC 600II, with Fanuc 18 0-MD control.
We just had a power "flicker" and now my machine control will only boot up to the date of manufature screen and has blinking (and beeping) alarm "NOT READY".
I have held down the LPQ and Cancel keys while powering up but that didn't help.
I noticed the Spindle Amplifier Module ( inside the main power cabinet ) will show 12 as soon as main power is switched on, then switch to 3 after a second or so, then switch to two flat blinking lights .
When I shut down the control (but still have main power turned on ) the Spindle Amplifier Module display switches to the number 24 and indicates an alarm.
Old 08-11-2011, 08:06 AM
bikecrazy is on a distinguished road
Hi, I have a very similar problem. have you managed to get your machine running again? Can you share what the cause was and offer a solution. Regards.
Need Help!- Hardinge CNHC I Startup problem outsource Hardinge Lathes 2 06-05-2009 10:00 PM
Newbie- Hardinge T51 turret problem gtsraven Fanuc 4 04-13-2009 06:52 AM
hardinge conquest 51 problem bassmastrbw96 Hardinge Lathes 1 09-04-2008 08:39 PM
G-Code Problem on my Fanuc Oi Hardinge Lathe Josh-PTP Fanuc 11 07-10-2007 05:42 PM
HELP!!! Smoked Spindle on Hardinge VMC-600II Janos Bridgeport and Hardinge Mills 0 01-19-2007 11:59 AM
