Old 09-12-2010, 02:47 PM
richclay is on a distinguished road
3d milled parts
Hello
I'm new to cnc machining and wondered if someone here could give me an educated guess as to how long the milling would take on shapes like the ones in the photo if they were 3d contour milled from both sides to a point where I could then tumble the parts to get the final surface smooth?
The parts will be approx' 10" long and made from aluminium.
Kind regards
Rich
Old 09-12-2010, 03:02 PM
awerby is on a distinguished road
It really depends on what machine you're using
A big mill with a fast spindle will be a lot quicker than a small one with a slow spindle. Aluminum also doesn't tumble-finish particularly well. Sculpture tools like this are usually made in wood (boxwood is best) - why aluminum? If you're looking to mass-produce these, CNC milling them one at a time isn't a particularly economical way to go. Use the CNC process to make masters, then cast from those to make your actual aluminum parts - that will go a lot faster, and the time it takes to do each original part will matter less.
Andrew Werby
www.computersculpture.com
Old 09-12-2010, 03:04 PM
Cruiser is on a distinguished road
You leave too many variables to calculate a time. Since time changes would be a direct relation to the type of holding device for each operation and the overlaps involved with the programed surface finish results expected, as well as the size and quality of the tool and its subsequent speed and feed rate etc. etc. etc..........
Don
IH v-3 early model owner
Old 09-12-2010, 03:17 PM
Hi Andrew
thanks for your reply, I'd be looking at milling them in multiples from sheet. Aluminium is quick to mill, fairly lightweight, and easy to get hold of. You're right about boxwood being the ideal but genuine boxwood only comes in logs of no wider than 6" diameter, once you move out from the centre this obviously gets a smaller and so even less efficient, it's also extremely expensive, difficult to get hold of and cracks during drying.
Do you have an idea how quickly a large vmc might contour one part, if it had say an 8000 rpm spindle?
Old 09-12-2010, 04:08 PM
Hi Don
thanks for your reply, the quality of the milled finish would depend on what I could reasonably get away with before tumbling them to produce a smooth rounded end result, the tumbled finish is the one that's going to be seen. I have seen the finish tumbled aluminium has and it's good enough for what I have planned. I'm not looking for a time accurate to the second, and I'm not asking about work holding, just an educated guess on the amount of actual cutting time for one side of the part.
Old 09-13-2010, 01:06 AM
Algirdas's Avatar
Algirdas is on a distinguished road
actual cutting time with 8000rpm will take 56 hours at least.
It's not proper to mill these parts. Make mold and manual finish after. Pressing is also good. Plastic or natural compound - the best. Hand carving much easier if You don't need mass production.
Old 09-13-2010, 04:00 AM
Hi Algirdas
I don't believe it would take 56 hours to mill the contours on that part.
I am aware that I could make molds and have them cast, or that I could hand carve them but there are reasons why I have chosen not to take those routes.
Old 09-13-2010, 11:08 AM
aucran is on a distinguished road
What about using a 4axis machine? Just leave a bit of stock on both ends that can be cut off with a band saw and buffed out, since these are going to be tumbled anyways.
At least that way you save the 2nd set up.
You would need to be pretty light on your cuts though, they look thin in areas and even made out of AL they would be easy to bend and break.
Not sure on time though
Old 09-13-2010, 12:22 PM
Hi Aucran
Thanks for your reply, it's nice to get one from someone who is trying to be genuinely helpful. I think a 4th axis setup wouldn't be as efficient as machining them from a sheet.
I'm really just interested in responses to the original question.
Old 09-13-2010, 01:11 PM
pontiacg5 is on a distinguished road
Your looking at several separate cycles, your not just going to cut shapes like that out of a sheet on a 3 axis mill without turning the work. I would guess that Algirdas guess is pretty close. You would have to make all sorts of fixtures to hold the work too, since it would be odd sizes after the first program.
Gah, thinking about it makes my head hurt. It would be 10X better from bar stock on a 4th axis and 100X better cast.
  #11   Ban this user!
Old 09-13-2010, 01:36 PM
diyengineer's Avatar
diyengineer is on a distinguished road
Originally Posted by richclay View Post
Hello
Kind regards
Rich
Cast them.
http://www.foundry101.com/search.htm
  #12   Ban this user!
Old 09-13-2010, 01:51 PM
ok my mistake, apologies to Algirdas, I thought he was just taking the micky. I figured I'd be able to just get some cam software and 3d contour mill from each side, I thought there would be some experimentation as to how long they'd need to be tumbled for to get rid of any ridges from the cutter.
Need A Quote- RFQ for part to be CNC milled fleisch Employment Opportunity 3 03-27-2010 12:39 PM
First milled PCB Jason Marsha PCB milling 36 11-18-2008 08:49 PM
Milled Out A Hovertank John Bear Ross Benchtop Machines 7 03-07-2008 03:14 PM
Quote on 4000 CNC milled parts please *URGENT* rpx1 Employment Opportunity 33 12-20-2006 01:51 PM
Need aluminum parts milled. will trade for beer :) Adam_b Australia, New Zealand Club house 6 08-30-2004 08:39 AM
