Old 09-11-2010, 08:39 AM
metalman4all is on a distinguished road
Clausing CNC Lathe Retrofit
I'm considering replacing the old Fanuc controls on a twenty year old Clausing 1000 CNC Lathe. The machine came out of a school and has seen little use. The Iron is like new, but the Fanuc AC spindle control board is bad.
With the cost of Faunc parts, would I be ahead to do a retrofit with Gecko drives and Mach3? Has anyone retrofitted a VS series Clausing 1000 (2000, 3000, 0r 4000)? What did you use and how much did it cost?
Old 10-19-2010, 04:26 PM
wikket is on a distinguished road
Any progress?
Did you ever get any info on this topic? Did you make any decisions or progress on this? I"m looking at something similar.
Thanks,
Mike
Old 10-19-2010, 04:56 PM
Al_The_Man's Avatar
The Fanuc model(s) were not mentioned?
Gunsmithing lathe - Clausing Colchester DPG Want To Buy...Need help! 0 11-30-2009 10:44 PM
Clausing N/C lathe Retrofit Ringleboy26 Vertical Mill, Lathe Project Log 1 02-16-2007 08:04 AM
Clausing 8520 CNC Retrofit? gunsmither Benchtop Machines 7 10-28-2006 01:56 PM
Clausing Lathe 13x36 Locster13 General Metal Working Machines 12 10-06-2006 02:23 PM
Clausing 8520 retrofit New2Brass General Metal Working Machines 0 03-13-2005 08:11 AM
