Old 09-10-2010, 08:49 PM
lourenco's Avatar
lourenco is on a distinguished road
3kw spindle miling aluminium?
Hi guys, i am from Brazil,
i want to buy a chinese 3kw spindle motor water cooled(24000rpm).
So i have some questions...
Can i milling aluminium easy?
i have a spindle with 600watts and 30000 rpm in my machine (homemade spindle-bosch)
i have some problems with finishiments, the aluminium fininsh is not shining...
I think 600 watts is to weak to machine aluminium , i can reard rpm dowing...
Now i can run feed rate 500mm/min and 1mm passes (end mill 6mm-4 theet) using 50% of end mill diameter...
and i would like to upgrade my milling machine and have a better finish
So, do you guys have some experiences on aluminium??
what you think about this chinese spindle??
what feed rate you guys use on alumnium with 3kw spindle...
Thanks so much and sorry about my english
Old 09-11-2010, 03:53 AM
Algirdas's Avatar
Algirdas is on a distinguished road
You need spindle run-out to be as small as possible for shining finish. For instance, Okuma spindles have < 1µm radial and axial run-outs typical. That's static. You need also to see if spindle unit is self-centering designed. Dynamic run-out will grow if not.
Revolution speed is correct for aluminum.
Old 09-11-2010, 10:31 AM
lourenco's Avatar
i have a strong machine but my spindle is not pro. my spindle is homemade(bosch)
my machine in youtube
YouTube - Milling machine cnc first test
this video has a old spindle 3600 rpm
so i want to buy a new spindle to work with aluminium...
i want to buy a chinese spindle, runs out 0.005 (3kw-24000rpm)
is correct?
can i make deep pass on 7075 with a 10mm end mill ?
what is the max. feed rate can i use?
anyone else work with aluminium?
Old 09-11-2010, 12:33 PM
Algirdas's Avatar
You need to set depth and calculate feederate according tool description
Old 09-11-2010, 06:17 PM
lourenco's Avatar
anyone has video with 3kw spindle milling aluminium ??
Old 09-11-2010, 08:24 PM
chinacut is on a distinguished road
We have videos that cutting aluminium,
Please contact me for detail,
My msn: chinacut@hotmail.com
skype: wdzhangying
Old 09-11-2010, 10:07 PM
lourenco's Avatar
how is the best tool to milling aluminium? (7075 t651)
i dont know if 3 or 4 flutes is correct.. i dont know what carbide is and what it do...
i want to know the best tool to have finish and performance on aluminium, and have the best shine...
please teach me some about tools in aluminium
can you guys help me?
thanks
Old 09-12-2010, 03:54 PM
universalfab is on a distinguished road
High speed steel 4-6 flute...
Old 01-14-2011, 10:13 AM
lourenco's Avatar
Hello staff,
My machine has a strong construction.
now I have my machine in a spindle of 3 kW and 24000 rpm
I am with some doubts about vibration
I only work with aluminum, in my last job I used a 12mm end mill and two fluts.
I used passes with depth of 1 mm in 600mm/min.
I use cutting fluid
vibrates a lot, and some parts shine and others do not.
I read somewhere that little load on the tool makes it vibrate. right?
the z-axis motor is engaged directly in the thread for a piece of aluminum.
A flexible coupling helps to reduce vibration?
What can I do to reduce vibration and improve the finish?
thanks
Aluminium profile u.k coleysbiscuit Want To Buy...Need help! 0 10-23-2009 02:20 PM
Profiling Aluminium Babba Benchtop Machines 13 12-28-2008 05:06 PM
CNC Machining miling and turning http://www.lbprecision.com chakaloso Product Announcements & Manufacturer News 0 06-30-2008 11:34 AM
Coolant for Aluminium Nigel_B Australia, New Zealand Club house 13 03-03-2007 04:25 PM
Cutting Aluminium blfuller123 DIY-CNC Router Table Machines 33 04-09-2006 06:49 PM
