Old 06-13-2005, 03:09 PM
djacob7 is on a distinguished road
Milling Brass Question
Hi all,
While milling a brass piece on my new Harbor Freight Mini Milling machine, The cutter (1/2" 2 flute) would once in a while dig into the cut and sieze the motor. This would happen mostly on down cuts and less on climbing cuts.
Everything on the machine was as tight as could be.
The cutter was extremely sharp. Could this be a reason? If so, what is the proper way of dulling the cutting edges?
Thanks,
Dan
Old 06-13-2005, 04:19 PM
HuFlungDung's Avatar
Moderator
If you don't mind dedicating one cutter to brass, the best method is to grind a radially centered flat inside the face of the flute. Or, you can also purchase straight flute endmills which will accomplish the same thing. The helix of the flute is what causes the "hog-in" problem.
This same trick applies to drills used in drilling brass. A small flat land ground inside the lip of the drill is enough to remove the helix of the drill for a zone depth slightly greater than the feed per revolution of the drill.
Thread milling, can anyone help jtrav General CAM Discussion 16 03-06-2006 02:25 PM
Why would this machine be bad for milling? jevs Knee Vertical Mills 5 06-16-2005 10:49 PM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 02:43 PM
pcb milling question NickLatech DIY-CNC Router Table Machines 1 03-04-2005 02:49 AM
Just a question about plunge milling. Machine1 Hard and High Speed Machining 4 01-28-2004 08:36 PM
