Old 09-09-2010, 12:29 PM
J.R. SWIGER is on a distinguished road
KERNEY-TRECKER HYDRAULIC SERVO ISSUES
ANYONE FAMILIAR WITH HYDRAULIC SERVO MACHINES? WE HAVE AN OLD 1967 KERNEY TRECKER 5-AXIS NC THAT WAS RECENTLY RETROFITTED WITH A FAGOR 8055 CONTROL. IT'S A LARGE CAPACITY VERY WELL BUILT MACHINE BUT I’M HAVING TROUBLE WITH ALL AXES WANTING TO OVERSHOOT THEIR POSITIONS. AFTER THEY OVERSHOOT BY ABOUT .01-.015 THEY WILL RETURN TO THE CORRECT POSITION. THE OVERSHOOT AMOUNT SEEMS TO BE DIRECTLY RELATED TO THE FEEDRATE. (FASTER=MORE). ALSO THE Z AXIS IS FLUCTUATING ABOUT .004-.006 ONCE IN POSITION. IT’S A HYDRAULIC SERVO MACHINE WITH INDUCTION SCALES. BUT I’M THINKING THAT THIS PROBLEM IS WITHIN THE CONTROL AND CAN BE FINE TUNED...BUT NOT SURE. WE HAVE GOOD DOCUMENTATION ON THE RETROFIT BUT THE GUY THAT DID IT IS NOT AVAILABLE ANYMORE. IF ANYONE HAS ANY IDEAS OR KNOWS OF A SERVICE TECH IN THE EASTERN U.S. THAT IS WILLING TO TAKE A LOOK AT THIS MACHINE, PLEASE LET ME KNOW.
Old 09-09-2010, 06:24 PM
Would it help to "sneak up" on the final position? decelerate into the last .100"?
Dick Z
DZASTR
Old 09-10-2010, 05:33 AM
The amount is reduced by decelerating but even at a lower feedrate of say 6 IPM it will still overshoot the position, which makes clean pocketing impossible. Also the fluctuation in z axis makes clean facing impossible as well.
Old 09-11-2010, 04:00 AM
Algirdas's Avatar
Algirdas is on a distinguished road
is the machine vertical? Then take a look, if Z axis is stabilised by hydraulic cylinder. The fluctuation may come from there.
In-position accuracy is up to control, of course. After You are sure mechanical condition of guideways and linear bearings is correct.
New Machine Build- Kearny and Trecker Milwaukee-Matic Series Eb K&T EB General Metal Working Machines 18 05-17-2012 02:22 PM
Large Kearney & Trecker HMC conversion. samco Vertical Mill, Lathe Project Log 47 12-08-2011 10:00 AM
Servo Drive Issues spaceacealpha Fanuc 1 06-16-2010 12:36 PM
Kerney Trecker Tape Drive Interface chammerbeck Machine Problems, Solutions , Wireless DNC, serial port 6 04-21-2008 03:02 PM
Rutex Servo issues. ty1295 Servo Drives 3 05-27-2005 11:10 PM
