Old 09-07-2010, 12:44 PM
bbbladeworks is on a distinguished road
How much horsepower to drill stainless?
Hello Forum, I come in search of metalworking knowledge. Seems like this is a great place for it. Really enjoying the forums so far.
My question: How much drill will I need to punch big holes barstock?
I need 1" diameter holes in (1/8" - 3/16") stainless steel for my neckknives and other projects.
1/2HP .. 3/4HP .. 1HP .. 1.5HP ?
Anyone have any experience boring holes this size? What will get the job done. I know my benchtop Delta won't get it done.
In the past I've paid a machine shop to do this, but I need to do this in-house now.
I'm looking at all the usual suspects, Delta, Rigid, Jet, Grizzly, or whatever Harbor Freight has to offer..
Thanks.
Brian
Old 09-07-2010, 01:20 PM
plasmator is on a distinguished road
There are different ways to machine the hole you describe. You can drill, drill/ream, mill, or bore (boring isn't drilling, despite common usage to the contrary). Do you know which approach you want to use?
Old 09-07-2010, 02:00 PM
I would assume drill would be the most direct approach. And I'd like to buy a drill press to get the job done.
I probably forgot to mention this is related to a new equipment purchase..
B
Old 09-07-2010, 03:01 PM
Fabio1 is on a distinguished road
Your best bet would be to get a bridgeport type machine and plung with a very short 2 or 3 flute endmill(coated would be best).Should have no prob doing this on a 220V machine.You will only need to run about 200 rpm and remember heat is your enemy with stainless so keep it cool.
Other options would be to punch it,waterjet or laser.If u have any of these in your area get them to quote u a price.You may be plesantly surprised.
Cheers
Old 09-07-2010, 06:35 PM
Cmailco's Avatar
Cmailco is on a distinguished road
Lightbulb
What kind of quantities?
Perhaps you should be looking at something more akin to a 'punching' machine or ironworker?
http://www.iron-workers.com/punching_machines.html
The Manufacturing Reliquary
http://cmailco.wordpress.com/
Old 09-08-2010, 12:02 AM
small scale
The scale is small, right now, no more than 10 holes of such size a month.
The punch and bridgeport would certainly be welcome additions to my shop, but I fear outside the budget for this particular task.
I've been meaning to contact the water people in my area anyway, looks like now is the time to do it.
Oh, and I also understand that while doing this on a drill is possible, there would be considerable wear on a bit performing this task repeatedly, correct?
A bit of that size = not cheap.
Thanks for your input guys.
Old 09-08-2010, 10:50 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
1" hole, carbide bit, stainless = 2.5 to 3HP to be comfortable.
HSS bit can't go as fast so 1.5 HP would do. Not sure how long that bit will live though.
HP calculations were done on G-Wizard.
Annular cutters are much more efficient than twist drills. You ought to look into those while you're at it.
You'll also want to budget a tool grinder to sharpen the bits.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Old 09-09-2010, 07:05 AM
UUU UUU is offline
UUU is on a distinguished road
You also need to think about/budget for how you're going to hold onto the stainless as you drill it. A drill that big with that much power behind it is going to give the mightiest of kicks if it grabs.
Old 09-10-2010, 08:17 PM
Cmailco's Avatar
Arrow
There have to be half a dozen or so "carbide" drill types in that size range, all of which vary in cutting geometry from the twist-drill split-point single-insert types to the double-insert drills like Kennametal's "Drill Fix". The amount of hp needed is totally dependent on the sfm and inch/rev, not to mention the cutting geometry.
That said, I'd always look to the drill manufacturer when calculating hp requirements with inserted-type drills.
10 holes per month and I think you'd get along just fine with a quality carbide tipped hole saw from Lennox, Starrett, etc..
Good luck.
Old 09-23-2010, 11:29 PM
kelvinguo is on a distinguished road
I sell waterjet cutting machine with high quality and competitive price from China.
The CNC five-axis dynamic water jet cutting machine is our newest product.
If you're looking for it please feel free to contact me directly at kelvinguo@syfos.com , I will send more details to you.
Need Help!- Drill bits for Stainless Steel Khalid General Metalwork Discussion 17 06-21-2010 08:20 AM
Pulley Diameters and Horsepower Help. Cartierusm Mechanical Calculations/Engineering Design 7 12-05-2009 02:35 AM
Newbie- Understanding the horsepower of a machine. MidFloridaTech General Metal Working Machines 14 04-11-2008 03:21 PM
Horsepower Calculations HFOSM General Metal Working Machines 3 01-17-2007 07:03 PM
HorsePower Question diarmaid I.C. Engines 12 10-04-2006 08:52 AM
