Old 09-04-2010, 06:57 PM
wariat is on a distinguished road
Mazak VQC 20/40b ATC Door Problem
I have a Mazak VQC 20/40b milling machine and my problem is that the ATC drum door opens slow. I replaced the pneumatic piston and the door started open normaly but would close slowly. I tried playing with the plastic switch on the pneumatic piston but did not help fix the problem. If anyone could help I would appreciate it.
Thanks,
Tags
mazak vqc 20/40b
Door interlock problem joshe76 Okuma 2 01-19-2010 02:58 PM
Turning off the door sensor on a mazak quick turn 6t lathe redfishoil Mazak, Mitsubishi, Mazatrol 2 05-01-2009 09:48 AM
Problem with door DMU 50V paris Deckel, Maho, Aciera, Abene Mills 1 04-12-2009 12:02 AM
Okuma door interlock problem ktb100 Okuma 1 03-29-2007 11:31 PM
shutting down door alarm for mazak t plus scott 54 Mazak, Mitsubishi, Mazatrol 0 12-13-2006 07:27 PM
