Old 09-04-2010, 10:19 AM
ultpd is on a distinguished road
Heidenhain tnc 426 error
I have heidenhain tnc 426 mill that had a problem with the gear changer and i managed to fix but now the control is stuck with a error 74. Improper speed range. that i cannot manage to get rid of . the machine allows me to turn the servos on and home the tool magazine but that is it. I can manually change between hight and low gear using the pneumatic solenoid. any ideas or suggestions would be greatly appreciated.
Old 11-08-2010, 09:01 AM
sank7378 is on a distinguished road
gear changer..
Hi there,
I'm sorry i cannot help but i do need your help on how to fix heidenhain tnc 426 problem with gear changer. if you don't mind if i'm asking how to fix it..
Tags
heidenhain tnc 426
BP Heidenhain error hmc710 Bridgeport and Hardinge Mills 9 10-09-2010 11:04 AM
Newbie- Error sending code to a Heidenhain 151b via Serial alib Machine Problems, Solutions , Wireless DNC, serial port 0 02-01-2010 10:50 AM
Need Help!- ERROR in Heidenhain anuevo CNC Machining Centers 0 07-28-2009 10:51 AM
Need Help!- Bridgeport 760\22 Heidenhain 370 "error 2 tool def" JNFSWE Bridgeport and Hardinge Mills 9 08-26-2008 01:45 PM
Bridgeport Interact 1 Mk2 Heidenhain error joegille Bridgeport and Hardinge Mills 4 03-12-2008 07:07 PM
