Old 08-31-2010, 11:07 AM
robd19 is on a distinguished road
Need Advice on Purchasing Amada Punch Press
Hi. I have been cruising this forum and have found tons of info. However, I need some advice on what machine to purchase. Our application is fairly simple as we need to punch sheets of brass no more than .160. By far the most common will be .040 and .050. Mostly 1/2" x .125" oval and 3/8" round holes. I have been searching the used market and there are quite a bit of machines available. It has been a bit difficult to ascertain what would be the most appropriate.
Electrical capacity is an issue where we are at so I believe a mechanical machine would be more appropriate as the power consumption appears to be about 1/2.
Also, it seems that being that I will be punching brass, a 22 ton machine should be more than enough.
I have been looking at older PEGAs from the late 80s and early 90s but I am open to any machine that would be appropriate for my application. I just want something solid and reliable with an interface that would be fairly straight forward for my people to operate.
Questions:
1) What are some machines that you would recommend?
2) Are there any major disadvantages with going with an older machine( i.e. 1987) that is in good condition? Can they be run with modern software? Is there a preferred software package that I should look for?
3) What are some things to watch out for when purchasing a machine like this?
4) Are there any models I should avoid because of history of problems?
Any info would be greatly appreciated . Thanks so much for taking the time to read my post.
Robert
Old 08-31-2010, 11:28 AM
Independent CNC is on a distinguished road
Post
I would take a look at Trumpf machine if you plan on expanding in the future. For older machines I would contact someone that does maintenance to see the availability of spare parts. I have heard there are some older Amada’s that are stout machines. Software should be no problem for older machines because most of them use basic G & M codes.
Independent CNC Programmer
www.independentcnc.com
My mission is to share CNC programming innovations for a lifetime.
Tags
amada turret press
Need Help!- Amada brake press controller nc9 r maplesiport Controller & Computer Solutions 0 07-15-2010 05:32 PM
alarma 400 amada coma punch ELFERNYBOY Spanish CNCzone 2 07-02-2010 02:28 PM
Amada Press Brake Controller problem jamesbond007 Bending, Forging,Extrusion... 3 10-17-2009 03:49 PM
Newbie- Amada Punch Retrofit Freecraft Controller & Computer Solutions 0 04-18-2009 01:39 PM
