Old 08-30-2010, 09:27 PM
billylennox is on a distinguished road
aluminum in my coolant!
whats up guys i work for a large firearms manufacturer in florida i run a mazak hcn 4000 its brand new with a consep 2000 chip conveyor. i only run 7075 aluminum and im having a horrible time with my coolant its either foaming so bad it overflows or the chips are so fine they get past the filters and into the lines in the spindle and backs up my coolant flow i need an answer or what to do? im useing trim e 206 now, ive herd of a coolant that castrol makes that lets the aluminum sink in the pan but im worried that the consep 2000 wont be able to do its job with the rotating spray drum? any suggestions guys?
Old 08-30-2010, 10:13 PM
Cmailco's Avatar
Cmailco is on a distinguished road
Yeah, installing an in-line filtration unit is a smart investment because they always pay for themselves in short order. Keller (http://www.kellerproducts.net/inline_filter.htm) is what I'm most familiar with but there are other makers out there as well.
The foaming issue is most likely from the water being too soft (hardness<70ppm). Could be from overly rich concentrations too. What do you typically mix to and how are you verifying that? Refractometer??
The Manufacturing Reliquary
http://cmailco.wordpress.com/
Old 08-31-2010, 01:55 AM
to be honest its just a tap? on a 55 gallon drum and i checked it with a refractometer its was about 3.5%
Old 08-31-2010, 03:38 AM
Algirdas's Avatar
Algirdas is on a distinguished road
I have my $0,02 here. We use 20µm and 10µm and 5µm filter bags for alluminum production machines. Maybe foam is for purpose - to have chips removed easily?
Old 09-02-2010, 05:03 AM
peaceandcalm is on a distinguished road
just use defoamer liquid, i always use it on coolant, works good...
Using coolant on aluminum Ed Williams DIY-CNC Router Table Machines 0 12-05-2009 11:43 AM
Newbie to CNC aluminum milling feed/speed/depth/coolant, etc. mrk General Material Machining Solutions 4 03-30-2009 01:51 PM
Aluminum Without Coolant DeusExMachina General Metalwork Discussion 5 02-27-2009 10:01 AM
Coolant stains on aluminum JpBinc General Metalwork Discussion 14 11-19-2008 10:11 AM
Coolant for milling aluminum rchunter94 General Metalwork Discussion 1 03-03-2008 03:04 PM
