Old 08-28-2010, 12:48 AM
isiahstites is on a distinguished road
Variable Frequency Drives?
Variable frequency drives, what are you guys using?
I have searched this forum and found very little in the way of info. I believe VFD's are better than phase converters correct??
Any help would be appreciated as I just bought a machine and would like to get it powered up in the next few weeks.
Thanks,
Scott
Old 08-28-2010, 02:05 AM
Khalid's Avatar
Khalid is on a distinguished road
One month ago, i received my VFD drive PUMA 2.2KW 6Amp... My Spindle Motor is 3Phase 380Volts 2.2HP
I read the manual more than 4 times and now i am able to wire it and control the VFD with Potentiometer, Forward, Reverse and some more programmable parameters.. I will soon use Mach3 to get it running..
I am interesting in this thread.. As soon you get time post about the progress..
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Old 08-28-2010, 08:58 AM
I guess I should put up some more info on my machine and the motor. I will post this information this afternoon.
I think mine is 3 phase 230 or 240 volt 3 hp.
Thanks,
Scott
Old 08-28-2010, 10:47 AM
Al_The_Man's Avatar
PH.C.'s are generally for powering the whole machine, VFD,s are primarily for controlling the rpm of a single motor as well as the possibility of converting 1 ph for a 3 ph motor.
Depending on the size and make/model of the machine, a VFD could be used on just the spindle and the controller and servo's fed off 1 phase, depending on the present set up of the machine.
Old 08-28-2010, 01:30 PM
Thanks for the reply Al,
This puts things into a little bit better perspective.
Here is my machine.......any recommendations?
Old 08-28-2010, 01:38 PM
Al_The_Man's Avatar
Allen Bradley system, looks like Westamp or similar drives, probably fed from a large 1 ph linear supply.
If my guess is correct you would only need a VFD for the spindle.
The controller is most certainly 120 or MAYBE 240 for the AB controller.
2 hp variable frequency drive (vfd) valmet58 Bridgeport and Hardinge Mills 1 01-23-2010 09:42 PM
Need Help!- PIC Variable frequency drive xlukkajr PIC Programing / Design 5 01-19-2010 11:27 AM
New Spindle + VFD Variable Frequency Drive Kelinginc Product Announcements & Manufacturer News 3 06-15-2009 10:06 PM
Variable frequency drive for high speed spindle icestation2 General Electronics Discussion 3 03-19-2009 12:20 PM
Variable Frequency Drives...how do they work? mastercnc General Electronics Discussion 4 05-27-2004 08:59 PM
