Old 08-27-2010, 12:47 PM
sabine is on a distinguished road
Question How do I Rotate the head on a YCM-40 Supermax?
I can't figure it out...we're trying to get it through a door...there seems to a bolt on the right side of the machine that we think is a worm gear, but the head acts as though it's locked into its current position. I can't find any other lever or pin that would hold it in place.
It looks like it's supposed to be able to rotate around the Y axis, as there's graduated marks for it (in fact, it's not at 0, so there's another reason to want to rotate it).
Please help
Thanks, Will
Old 08-27-2010, 01:20 PM
Karl_T's Avatar
Karl_T is on a distinguished road
AH, I broke my worm gear learning this the hard way.
The nut and threads you see right behind the arrow for rotating is the end of a taper pin. You need to pull that out BEFORE turning on the worm gear.
Karl
Old 08-27-2010, 05:05 PM
Karl
Thank you.
Problem- Can't Rotate Head! tall_penguin HURCO 8 07-07-2009 01:55 PM
Problem- rotate? gromit68 Alibre Design 3 09-06-2008 02:07 PM
Rotate G68 cadman@teluspla Haas Mills 8 05-08-2008 03:39 PM
rotate on axis A tonyas Mach Software (ArtSoft software) 0 01-03-2008 04:20 AM
Rotate head SPEEDRE Benchtop Machines 3 12-23-2007 12:44 PM
