Old 08-26-2010, 10:22 PM
Surjit is on a distinguished road
Arrow Z axis of CNC Machine
I have 5 Sodick CNC Machining center 450 and 600. I am having a trouble on Z axis on one machine. I changed the Z axis Motor and Servo Drive with 3 times from my other Sodick machines. My problem is Machine done with homing-OK. If I move axis manually, Z axis stuck randemly any where. and machine has to shut down, again power up and home ok but moving it will stuck. If I try to run the program than Z axis getting stuck at about 95-100MM down from Home positions. All drive and Motor I replaced are working on other machines. Motor and drive is made by Panasonic Minas -Any help, Thanks in advance-Surjit Virdi-surjit@m2sinc.com
Tags
cnc, servo drive, sodick, z axis
A 5-axis CNC machine including a rotary axis synthetiklone CNC Wood Router Project Log 11 05-23-2012 09:31 PM
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
5 axis cnc machine xa_shall General Metal Working Machines 2 02-07-2007 03:58 PM
4 axis controller for 3 axis machine? tybrenis CNCzone Club House 8 01-19-2007 09:12 PM
5 axis CNC machine? jkyle69 DIY-CNC Router Table Machines 7 01-17-2006 05:41 PM
