Old 08-26-2010, 05:55 AM
Mooping is on a distinguished road
Red face Cutting lathe question
Firstly ,[/B][/B] My company is a machine shop, Almost all of job are threading on pipe ( Casing , Tubing ) with various thread licenses. The pipe mostly use in Petroleum field. The pipe material is same AISI 4140. And size start from 2.375 inch to 7 inch. For me , It is a first time with lathe field. And I haven't any technical knowledge about lathe. I just know basic lathe that I read on internet. Please help me by advise me with these questions as below;
1. If I want to threading pipe 7" OD , AISI 4140 , With Carbide Insert. What is the proper speed , Cutting Depth with Feed Constant.
2. What is the main cause of " Vibration while threading" ? How to solve it?
3. If I clamp object with chuck by "External Clamp". It is need to set up
jaw distance when OD is changed? ( In fact , 4" OD and 4.5" OD can clamp without set up jaw. So I want to know relation between OD and Jaw distance )
Thank you very much for any advices.
Best Regards;
Mooping
Old 08-26-2010, 06:15 AM
Algirdas's Avatar
Algirdas is on a distinguished road
sorry, I'll not give an exact recipie. It is a combination of factors by following:
1. Carbide insert recommendations on that material. Cuting depth combinations with cutting speed. It's up to insert producer. Granlung's carbide insert is not the same as Iscar's.
2. You select proper speed in a basis of machine capability - torque and revolution. Check, if You can ensure proper chucking of workpiece at that conditions.
3. The last is Your own decission. You have few options now and now You decide whether You need make it faster or to save insert for longer work.
I'll not tell about cause, because it's easier to show alive or in pictures, than to tell. Take steady rest, this s a solution. Stifness of tailstock is very important also.
Check manual of chuck. Some have marks, to know if travel of master jaw is in between allowable limits.
Old 08-26-2010, 08:44 PM
Thank a lot !
lathe oils (way, cutting etc) help Speedygonzales General Metal Working Machines 0 07-11-2009 06:41 PM
Cutting question ZigMan DIY-CNC Router Table Machines 11 08-03-2008 02:38 AM
Cutting threads on lathe... WilliamD General Metal Working Machines 2 11-21-2007 07:55 PM
Another Stainless Cutting Question JMFabrications General Metalwork Discussion 11 06-16-2006 06:07 AM
Problem cutting arc with lathe. mudwhump G-Code Programing 9 05-23-2004 12:19 PM
