Old 08-25-2010, 08:38 PM
diesel dave is on a distinguished road
Surface finish issues
The control is Yasnac MX1, machine is a Matsuura mc-500v2
When I first bought the machine I replaced the x axis encoder because the PO hit it with a forklift
No damage to anything else just hit the cap of the encoder.
So I bought a new one and installed it and adjusted the parameters so it would home correctly.
One thing I noticed about the old encoder is that it had a glass ring inside it that looked like it was counting rev's or something, the new encoder I got did not have a glass ring in it, the servo shop I bought it from said this was not a problem (again no idea if this is right or not).
So now that I had a new encoder I got the machine up and running for a few months. I than decided to replace all the axis ball screw support bearings and rebuild the way lube system. In doing this I discovered the X axis servo was actually full of way lube because the coupling box that joined the servo/coupling/ballscrew was full of way lube because the drain hole was clogged. I pulled the brushes out and they looked fine. I drained the servo and sprayed some brake clean in there to get all the oil out, I do believe we were successful in draining all the oil out of the servo. Being that this is obviously less than ideal we decided to swap this potentially problematic X axis servo/encoder to the Y axis as the Y axis is significantly easier to remove than the X axis should we have any problems in the future.
*the problem is that straight X,Y,Z moves leave a perfect finish, as do interpolation and arcs. The problem is when I do a XY movement for angle like a 45*.
Here is an example part, the bottom edge is is a straight x axis move, and the surface finish is great:
Now the other two edges:
The finish quality does not seem to change with feed rate or spindle speeds, I have tried from 10-70ipm and a wide variety of tooling and tool holders with no luck.
Suggestions?
Old 08-25-2010, 09:45 PM
rock4xfab is on a distinguished road
How does the ID portion compare in the same angles... Compared to the Profile. Also are you hogging the material out on the 45 angles or is the part saw cut so you only have one side of cutter engaged. Are you performing a finish pass??
Old 08-25-2010, 09:58 PM
ID and OD profile finishes are the same, yes I am taking finishing passes. There is some sort of motion control problem, I just don't know what.
Old 08-25-2010, 11:16 PM
Cmailco's Avatar
Cmailco is on a distinguished road
Could be scale mismatch, indicating that the servo loop gains need adjustment. Just an educated guess on my part. I'd suggest a ballbar test because that eliminates all the guesswork real quick-like.
Best regards,
Chuck
The Manufacturing Reliquary
http://cmailco.wordpress.com/
Old 08-25-2010, 11:40 PM
Best regards,
Chuck
Don't ball bar tests just check interpolation? I've heard that some servo drives have a seperate tuning option for arc or circles, which my machine does fine. Would this still help?
Old 08-26-2010, 12:19 AM
Cmailco's Avatar
Interpolation may look fine to the eye and may 'check' fine with a plug gage check, etc., but very well could be oval at 90º apart. Which is typically what happens in a servo or scale mismatch situation. It may not even show up much in larger interpolations but a technician will typically look for it in a small ~.600 diameter check if it's suspect.
That said, I haven't seen a ballbar check that wouldn't catch servo gain errors yet but there are LOTS of controls out there and I sure as hell haven't seen them all.
Old 08-26-2010, 12:26 AM
Ok, good to know, I'll make some calls about ballbar test tomorrow.
Old 08-26-2010, 02:01 AM
Cmailco's Avatar
Thumbs up
Post back here and let me know how that goes Dave.
Hope they can get you all straightened out with this issue... I know how frustrating it can be.
Regards,
Chuck
Old 08-26-2010, 12:25 PM
I'll be sure to report back. Any indication of what a ballbar test may be worth?
Old 08-26-2010, 01:07 PM
Cmailco's Avatar
Last time we had a guy come out, it was $250 + 1.5 hours worth of labor at $90 per hour. I'm sure rates fluctuate area to area and some techs may even charge for travel, so it no doubt varies but I'd venture to say that somewhere between $350-450 is a decent ballpark.
Now, if you can get in good with a machine tool tech who likes to make a little money on the side when he's away from the factory office.... well, those are great to have around!
  #11   Ban this user!
Old 08-26-2010, 04:09 PM
Thanks for the info Chuck.
Does anyone have any insight as to the gibs being a potential problem?
  #12   Ban this user!
Old 08-27-2010, 11:23 PM
Ok so I checked the gibs today, they are all in spec as per my matsuura manuals.
I decided to check the brushes on the servos today as well.
I had actually never checked the brushes since I had everything apart last year, I can't believe I never checked the servo that had oil in it especially.
Anyways you can guess which one had some crud on the brushes.
I got that one all cleaned up. I'll check on it again after a week of running.
After all this I called the guys at Matsuura, they said there is no reason to tune the servo drives. They said the problem is likely that the tachometers just need to be cleaned. So I'll do that in the morning. Any suggestions on what I should use to clean the tach?
Surface finish issues on VF3-SS-YT flatfnder Haas Mills 149 08-11-2011 06:14 PM
Need Help! ASAP surface finish issues rough_cut Canadian Club House 15 03-25-2010 09:31 AM
Milling wax, issues with surface finish.. srmaietta General Jewelry Design Software 3 10-12-2009 09:41 AM
Fly Cutter Surface Finish Issues DeusExMachina Taig Mills & Lathes 4 04-23-2009 08:37 AM
Surface Finish Issues Re-visited 1ctoolfool Haas Mills 13 11-30-2008 09:02 PM
