Results 1 to 2 of 2
Thread: req surface roughness
    fsa
    fsa is offline
    Aug 2007
    PAKISTAN
    Question req surface roughness
    hello every body
    i ahve a question regarding surface roughness on milling operations.
    how can we achieve desire roughness thru feed and rpm on milling.for example my req roughness is Ra3.2 now for it what is the feed and rpm for achieve it.
    fsa
    Registered Algirdas's Avatar
    Mar 2009
    Lithuania
    maximum revolution minimum feederate. Surface roughness depends on spindle dynamic run-out. For good quality spindle static run-out of 1µm is allowed. Less is better, but difficult to measure. If You have static radial run-out more, than 4µm, forget about clean surface at all.
  1. Gecko 540 Stepper Motor Roughness
    By grossmanator in forum Gecko Drives
    Last Post: 08-24-2009, 02:16 AM
  2. Ball Screw Roughness
    By mre1000 in forum Linear and Rotary Motion
    Last Post: 06-06-2009, 11:18 AM
  3. Need Help!- MX3 SURFACE TO SURFACE TRIM
    By 82rouled in forum Mastercam
    Last Post: 05-18-2009, 01:02 PM
  4. Need Help!- Surface to Surface Filleting and Trimming
    By cowpoke in forum Mastercam
    Last Post: 03-17-2009, 09:42 AM
  5. roughness in spindle
    By fourperf in forum Haas Mills
    Last Post: 03-06-2008, 10:36 AM
