Old 08-20-2010, 01:09 PM
borne2fly is on a distinguished road
Newbie looking for info
I was looking at a used Fadal 40 until I realized it wouldn't fit into my garage
So now I'm looking for a smaller VMC or mill that uses a true closed loop servo system (no open loop steppers), but I'm not sure what options I have, and I don't know exactly how to i.d. a stepper vs a closed servo by looking at it.
Someone mentioned a Parker cnc knee mill ..... no enclosure but that's ok for what I'll be doing, but again how can I tell if it's servos or steppers?
Old 08-20-2010, 07:11 PM
rock4xfab is on a distinguished road
Why Servo vs stepper.... I know why I dont use one, but if you find something with glass scales it does not realy matter.
Old 08-20-2010, 09:18 PM
I was told that steppers are generally run open loop and can lose steps under heavy loads, but servos always run with a scale to close the loop and don't have this problem? Not sure if this is right.
Old 08-21-2010, 09:02 AM
Konstantin's Avatar
Konstantin is on a distinguished road
If you run a motor beyound its capabilities, like too fast, it will loose steps, no matter if a servo or a stepper. In my friends mill setup, servos with geckos, if a servo looses position, that drive will enter in error mode and wont move while the rest of the servos keep working. So if z suddenly fails and stops going up it could run into stock in a very nasty way.
A stepper that looses a step then it will lag behind in gcode vs the real position and the machined geometry will be different.
While you design your machine choose the motors that will be able to move the loads, then it will be ok.
Old 08-21-2010, 11:35 AM
Ok, this is starting to make sense now ..... I always wondered what happened if a servo system was overloaded. So do servo systems have any real advantage over steppers?
Newbie needs info! GeeBake Benchtop Machines 21 08-22-2010 01:40 AM
And Yet.... Another newbie that needs EZ trak info. StilaR8dr Bridgeport and Hardinge Mills 13 05-18-2009 09:14 PM
First mill! Newbie looking for LOTS of info... Farasien Benchtop Machines 2 06-12-2008 10:21 AM
VF3 startup info for newbie wddanie Haas Mills 4 01-22-2008 08:10 AM
Speeds and feeds info for a newbie Involute General Metalwork Discussion 3 03-23-2007 08:37 AM
