Old 08-20-2010, 11:51 AM
blakemachine is on a distinguished road
Exclamation Matsuura 1000VS2, 4th Axis Alarming out
Ok, I have a Matsuura MC1000VS2 Machine, with a 4th axis. I have used the machine flawlessly for about four years. I use the 4th axis three of four times a year, and it is off to the side other times. I went to hook it up recently, set my 7001 and 6023 parameters accordingly. Reset the machine, and now it alarms out with the fuse blowing on the 4th axis servo drive board. I started investigating by first tearing into the 4th axis servo DC motor. Brushes look good, no moisture, etc. I then looked into the thermal overload switch, it is good, and test ok. I then start to look at the cables, I ohmed out the cables, going to the 4th, and nothing is crossed, or shorted there. I then completly disconected the main power cable at the motor, in the 4th, only leaving the Thermal overload switch connected, so basicly no power wires going to the dc motor. It still alarms out. I then go and leave the encoder cable connected, at the machine, but dissconect the power cable, and just jumper across where the thermal overload switch is on those pins, to simulate the normaly closed situation of that, and it still alarms out with blowing the fuse on the 4th axis servo board. The alarm is 334.
Any ideas where to look next. So basicly I am ruling out that the 4th has anything to do with it. Any help would be much appreciated. Thanks.
Matsuura mill alarming out. Can anyone verify my post? blakemachine General CNC (Mill and Lathe) Control Software (NC) 2 03-31-2010 12:32 PM
Matsuura Mill With yasnac controll, overload in x axis on rapid. blakemachine General CNC (Mill and Lathe) Control Software (NC) 2 03-03-2010 07:45 PM
Need Help!- G71 taper turning - why alarming out? bullandbladder G-Code Programing 3 02-18-2010 01:05 PM
PSS1 and PSS2? matsuura Y axis. integerspin General Metal Working Machines 0 03-01-2009 01:18 PM
Need Help!- Servo Alarming still Dustin L Fanuc 2 10-02-2008 06:21 PM
