Old 08-19-2010, 10:31 AM
falcantara is on a distinguished road
Which one will you get?
Hi
I am a newbie with CNC, and I am looking for a rather inexpensive 5'x10' plasma cutting table.
Which one is a better choice?
I have quotes from EZ-Router and TorchMate.
Any advice will be appreciated.
Federico
Old 08-19-2010, 05:11 PM
jimcolt is on a distinguished road
Both good machines.....the key to good plasma cutting on any cnc machine is 1. A good fullfeatured THC (torch height control), and 2. A good quality plasma system.
The height control needs to be able to find the surface of the plate before each cut, retract to the manufacturers recomended pierce height, as soon as the pierce is complete it needs to index to the recommended cut height, then as the machine starts moving in x and y directions needs to monitor arc voltage and adjust z axis height real time. Cutting without a THC will provide extremely short consumable life and widely varying cut edge angularity as well as dross. Don't let anyone tell you you don't need a full featured height control.
On the plasma....look for a non high frequency start system that has piercing capability (don't look at the hand torch specifications....look at machine torch specifications, as they are vastly different.....even if you will be using a hand torch on the machine you still need to look at the plasma systems machine torch pierce and thickness capability).
The easy choice.....Hypertherm. I am a bit biased, but they have the best quality plasma in terms of reliability, cut quality and long consumable life....made entirely in the US as well.
Jim
