Old 08-11-2010, 04:57 PM
produca2 is on a distinguished road
Can not figure out Yasnak control panel on Matsuura MC-500V
So I have experience on HAAS control, Fanuc control and Fadal control panels. I recently purchased a Matsuura MC500V with a Yasnak control panel. This is my very first machine purchase, and would like to use it to make me some money. I can get the machine to Jog in all three axes, but I can not figure out anything else on the machine. I know my g and m code back and forth, I have read the manual given to me with the machine. I just cant seem to get the hang of it! Can anyone recommend any tips or tricks, or possibly a service in Southern California that might help me out? I would really like to get this machine cutting some metal. Thanks in advance.
Old 08-11-2010, 05:36 PM
Brian FRF is on a distinguished road
First you need to home the axis. Flip switch for "zero return" and jog all axis til they stop. The lights for each axis will light up when they hit their limits. I then do g92 on all, and use this for machine zero. All my programs pull up fixture offsets, found in "settings" a few down. Youll have to look in the manual for what setting for which axis, under different g codes.
Programs are named "O####" The first is not a zero, but a letter O.
Also, these controller do not like spindle control on the same line as coolant control. IE m3 s1000 m8 will not work, it will error.
Hopefully this helps a little.
Old 08-12-2010, 11:29 AM
This will probably help:
http://www.stanford.edu/group/prl/do...ete/RunRed.pdf
Old 08-16-2010, 10:35 AM
I cant even make the spindle turn on in MDI with a simple s100 m3 line. It keeps giving me alarm 23 or 14. I assume it is because I have not homed my axes?
Old 08-16-2010, 10:37 AM
Brian=AWESOME. Thank you
Old 08-16-2010, 10:50 AM
I believe the spindle wont turn on until it has been homed.
I also always put the m command before the speed, but I dont know that it matters either. ie "m3 s100"
Old 08-16-2010, 10:52 AM
I have not tried that yet. I will this evening.
Old 08-23-2010, 09:56 AM
ok...so I got it to move to the home position, and got the spindle to fire up and got a tool change out of it! YES!! thanks for your help guys. The PDF from BrianFRF was a godsend! Thank you Thank you! If anyone else has any other tips/tricks I might want to need or want to know about I would be glad to hear them.
Old 08-23-2010, 10:04 AM
Always amazes me that the stupidest stuff is never in the manuals. I found that PDF when I first got this machine, and helped me the same as you! "turn the machine, flip this, push that."
Have fun making chips!
Oh, FWIW, after milling circles, youll need g1 or g00. And m3, m8 must be on separate lines, as with m5, m9.
And if you havent found them yet, look for g54-g59, fixture offsets. Then all your offsets are off home position. So you can turn the machine off, turn it back on, home, and start running again. No need to find zero on your part, its stored as a fixture offset.
Old 08-23-2010, 10:54 AM
So instead of an m30 I need a g1 or g00 at the end of my program?sounds like I am gonna have to make a new post for mastercam.....
  #11   Ban this user!
Old 08-23-2010, 10:59 AM
Sorry, that reads a bit confusing.
End of the program is still m30.
If you are using mastercam it will take care of this. However many controllers Ive used dont require a g1, after a circular mill, g2/g3. Yasnac does. Its confusing because the error will show up, highlighting the g2/g3, and its actually because a g1 is missing from the next line. Does that make sense?
  #12   Ban this user!
Old 08-23-2010, 11:07 AM
GOTCHA! I was thinking I had attached myself to an alien control panel I was going to have to learn an entire new language to control! lol. Thanks for clearing that up.
Matsuura MC-500V Tool Changer Problem nlh General Metal Working Machines 25 03-06-2011 04:50 PM
Need Help!- Matsura MC-500V with Yasnac 3000B control nnpepe Want To Buy...Need help! 0 06-26-2010 10:51 AM
Matsuura MC-500V Upgrade wyobmf Vertical Mill, Lathe Project Log 0 05-22-2007 09:12 AM
Mazak / Yasnak MX3 control toolsetter soszi1950 Mazak, Mitsubishi, Mazatrol 1 02-10-2007 08:24 AM
Mazak VTC41L yasnak control +programming soszi1950 Mazak, Mitsubishi, Mazatrol 7 01-31-2007 07:11 PM
