Old 08-09-2010, 03:56 PM
j1979 is on a distinguished road
CNCDIY owners
first of all if this is the wrong section im sorry! the forum has so many different sections i did not know where to post. i am new to CNC and infact milling in general. the wiring and computer stuff is not a problem and doesn't daunt me. but when it comes to choosing a machine am a little stuck. I am a complete noob so if i say something stupid sorry.
i want to mill aluminium to, possibly 10mm deep in some areas. Speed is not an issue as i will only use the machine infrequently.
ok after after looking at the sable 2015 the v90 and various others, i think im going to opt for the CNCDIY CNC2520
http://sites.google.com/site/cncdiymachines/cnc2520
it looks like it will fit my needs OK. Does anyone own one of these and can they give me any advice. or am i totally out of my depth, and i need a much more powerful machine for my intended use?
thanks in advance
Old 08-09-2010, 05:15 PM
MrWild is on a distinguished road
That machine looks fine for wood. It is not good for aluminum. Why is it not good? A serious lack of rigidity. Every rail is unsupported. These unsupported rails will allow vibration to ruin every cut in aluminum unless you take VERY light cuts. The spindle is a high speed spindle and is made for wood. Again, extremely light cuts at very fast cutting feeds might let you cut aluminum, but if you think you can take cuts 10m (3/8") deep, the answer is no, no way, not with this machine.
Old 08-09-2010, 05:37 PM
yes i didn't mean in one go, i mean to 10mm deep with several passes. surely there is software out there that can do that? I am making aluminium enclosures for custom motherboards.. the bottom part of the enclosure will need recesses for components.. like a 7 - 8mm deep hard drive.
would you say this style, is more rigid, as the table moves not the arm?
http://sites.google.com/site/cncdiymachines/cnc2518
Old 08-09-2010, 06:16 PM
Again, the rails are unsupported. Vibration ruins cuts and cutters. Once a cutter starts degrading due to chipping from vibration, it gets worse fast. What kind of aluminum are you cutting? How big a cutting area do you need? Oy, I just looked at the motors. An even firmer NO WAY. Many machines clam CNC capable, but the axis motors and drives are only good for light duty. Notice the note by the motor stating (used). Usd motors of puny size with weak drives that ham string you into not being able to upgrade without major extra expenses make these machines poor choices. While aluminum is easier to cut than steel, it is a LOT harder to cut than wood and plastic. The pictures show it cuts plastic, wood, and .002 thick copper on PC boards.
I realize you are on a budget, but going cheap with something that appears like a good deal will ruin a business fast when it fails you.
Old 08-09-2010, 06:38 PM
Thanks for the advice. the maximum size will be 170mm x 260mm x 10mm.
are there any machines you can recommend?
Old 08-09-2010, 07:46 PM
Walky's Avatar
Walky is on a distinguished road
Remember you'll need some extra room for clamping the piece, and you must consider the tool's width, plus a safety margin (cutting into a clamp is no fun).
My machine uses supported rails on all axis (sbr16, seem to be the same used in the Sable's X axis), anti backlash nuts and 280oz-in motors running at 41V, ~2.5A each (many, many times more powerful than the motors on the DIYCNC and Sable you are looking at), and I still try to cut no deeper than 0.15mm deep per pass, 35IPM when using a 3/32" endmill on aluminum. My machine's structure is made of MDF, though, but using torsion boxes and some threaded rod for reinforcement of the Y axis. If you are thinking on hollowing a 200mmx200mm aluminum block with the Sable or other similar entry level machine, I bet it could take days.
Sbr16 bearing blocks have two adjustment screws (on top and on it's side). I found it takes a lot of pressure in these to get a really tight fit into the shaft (these bearings, when tightened, become hard to move through the shafts even by hand); with strong motors it's OK, since these can have the extra force needed to move each axis, but with small ones I don't think it will be enough, since the bearing blocks would be too loose.
BTW, as MrWild said, PCB milling is nothing like metal milling; PCBs are actually quite soft and easy to work with.
I still think the Sable seems like a really, really nice machine for the price, I just think it's just not meant for aluminum cutting (engraving, at most).
Old 08-10-2010, 07:22 AM
thank you for everyone's help an input. And i have taken this onboard and changed my expectations of what these machines can do. So my next question is..
does anyone know of a kit that will perform cnc aluminium milling out of the box? like i said speed is not a major issue. is the Fireball v90 more suited or is this likley to suffer the same problems?
Old 08-10-2010, 01:42 PM
Walky's Avatar
The v90 would be more pòwerful than the Sable, but probably a lot less rigid so I don't think it would be a good idea (I could be wrong).
How much do you want to pay? I would go for a real mini mill if I wanted to make aluminum, but of course that takes the cost quite higher.
Old 08-10-2010, 02:15 PM
http://www.axminster.co.uk/proxxon-p...5/?src=froogle
something like this?
i don't want to spend more than £1000 ($1550), ideally £700 ($1000) but if going for a mini mill, the CNC stepper motors would not be needed at the start and i would retrofit, in the future if needed. the machine doe not need to be CNC it would just help in the long run.
what size motor would i need to mill aluminium? i presume a basic mill with a 200w motor would not be powerful enough?
any suggestions, around £700?
Old 08-10-2010, 03:41 PM
awerby is on a distinguished road
That Proxxon is a really tiny machine
The site doesn't give the actual travel dimensions, but it's nowhere near the size you said you wanted. (As I recall, they're about 3 inches in X and 2 inches in Y). If you're making aluminum jewelry it might work for you, but otherwise, keep looking. You might be able to buy a used CNC mill and retrofit it with new controls, or build something yourself (if you're good at scrounging components) but I don't know of any CNC mills capable of reasonable cuts in aluminum pieces that size which sell new for the amount you want to spend, especially in the UK where everything seems to be more expensive than in the US.
You might be able to find a low-quality manual Chinese mini-mill within your budget, but they don't make the best candidates for retrofits. An older CNC mill with a blown controller might be a better bet - you can sometimes find them for the price of the scrap metal they contain.
Andrew Werby
www.computersculpture.com
  #11   Ban this user!
Old 08-10-2010, 08:59 PM
http://www.bzt-cnc.com/product_info....ZT-PFL330.html
what about this? it looks a little better built.
when you say the rails are unsupported, i am not 1005 sure what you mean.
  #12   Ban this user!
Old 08-10-2010, 09:19 PM
Walky's Avatar
Supported rails means the rails are fixed into solid supports that prevent flexing (and vibration) of the shaft under heavy loads; the supports are then fixed into the machine's gantry.
It's something like this: http://www.todomercado.com/tm/aviso/..._Alucarudo.jpg
Unsupported rails have a much higher tendency to flex, depending on their lenght and diameter.
The machine you mention seems nice, motors look to be Nema23 around 300 oz-in or something like that. Fixed gantry is nice for metal working. Still, I'm no expert (been a cnc hobbyst for less than 2 years) and have no first-hand experience with machines others than my own builds (I've only used supported rails so far), so I wouldn't dare to say if it would or would not work for your needs. It still seems much, much more adequate for aluminum milling than the Sable and V9, I'm just not sure if it's enough. I'd start by looking for info on the machine (by actual owners) and looking if thar website has a good reputation.
BTW, that machine doesnt seem to include a controller board, nor a spindle
Need Help!- KX1 Owners LOOK! deanler Benchtop Machines 2 06-26-2010 07:11 PM
To all your sherline owners nofx Benchtop Machines 9 06-11-2010 08:36 AM
Any LMS CNC owners out there? slawsonb LittleMachineShop CNC Machines 1 05-15-2010 10:09 AM
Ronnys CNCDIY 3040 router ronsand Norwegian Club House 5 04-11-2010 04:10 PM
Any CS 250 Owners out there? Polishpiper Mori lathes 2 06-15-2009 05:40 AM
