Old 08-07-2010, 11:25 AM
andypugh is on a distinguished road
Non-Circular Turning
I have been experimenting with non-circular turning, using synchronised motion of the X axis with the spindle on my 7x14 lathe.
It uses a custom HAL component in EMC2, which takes the output of the spindle encoder and uses that and a lookup table to calculate an offset to the X-axis position that is then passed on to the step generator.
Whilst the shape being turned in the video below is approximately circular, that is only because my spindle is very short of torque at low speeds, my X-axis is fairly slow, and that is the most elaborate shape I could manage.
It would be perfectly possible to alter the amount of offset on the fly, to make really rather odd shapes. multi-lobe cams would also be possible, limited mainly by the clearance angle of the tool.
YouTube- ‪eccentric‬‎
Old 08-07-2010, 04:16 PM
mcphill is on a distinguished road
Nicely done! With a servo for speed and torque, you could turn some really interesting shapes...
Old 08-08-2010, 04:51 AM
Algirdas's Avatar
Algirdas is on a distinguished road
Very nice! congratulations. You need Y axis or possibility to change cutting (attack) angle to have more complicated shapes done.
Need Help!- Circular Cut mikelohj LinuxCNC (formerly EMC2) 1 06-18-2009 12:19 PM
What do you know about this circular saw??? mailloux WoodWorking 5 10-16-2007 10:34 PM
Circular Cut Sanghera GRZ Software- MeshCAM 13 11-13-2006 10:26 AM
non-circular CNC turning. oldguy General Metal Working Machines 2 04-21-2004 08:52 PM
non-circular lathe turning Help! oldguy General Metal Working Machines 2 04-06-2004 11:55 AM
