Old 08-02-2010, 05:11 PM
Russedwards is on a distinguished road
What machine?
Hi
I am new to cnc machining and need help selecting a suitable machine for my requirements.
I am looking to mill small complex shaped parts, similar in size and shape to a modern golf putter head out of aluminium.
Tolerance isn't particularly high at 0.001".
Any suggestions for a suitable machine for this application. As cheap as possible!!
Old 08-02-2010, 05:28 PM
MrWild is on a distinguished road
How much money do you have? What are you looking for? Turn key CNC? Build it yourself? Any machine you buy will also need a tooling package. You will also need a CAD/CAM package unless you know how to hand code. Figure on spending at least $3k for the lowest end everything, up to $15k for good everything. It gets much more expensive if you're talking about a business.
saleCNC laser engraving machine and CNC woodworking machine zhangrui1588 Laser Engraving & Cutting Machines 3 05-08-2011 03:54 PM
cnc router/CO2 laser machine/cnc plasma cutting machine cncengraver Chinese Machines 0 06-25-2010 09:48 PM
Need Help!- Hardinge CBN Turning Machine with GE Fanuc Machine Model CS- 51, S.No. CL – 622 -BSP M.RISHIKESH Hardinge Lathes 1 11-20-2009 06:03 PM
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 09:37 PM
