Old 08-02-2010, 12:51 PM
rylanrouge is on a distinguished road
tight threads with angle head
Machine: Niigata 80 Fanuc control. When using a right angle head with a 9/16-18 tap, the threads are very tight. I'm using G95 and have a metric program, Feed 1.41 Speed 170, we've checked runout on the tool which is fine, used different 9/16-18 taps, and the threads were still tight. After using a tap in the angle head, we'ld take the tap out and use it without the angle head, and the threads were fine. Any suggestions on what could be causing the tight thread? Thanks.
Old 08-02-2010, 12:53 PM
Algirdas's Avatar
Algirdas is on a distinguished road
tap wear
Old 08-02-2010, 03:27 PM
Eurisko is on a distinguished road
Check the gear ratio of the angle head. If it is not exactly a 1:1 ratio, it will mess up your threads.
The easiest way to check it is to enter a spindle speed in MDI, then verify (with a tachometer) that the spindle speed is correct.
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
Old 08-02-2010, 11:02 PM
HuFlungDung's Avatar
Moderator
Is the controller capable of rigid tapping in other planes? You might need some floating compensation in the form of a floating tap driver.
right Angle Head help inkydo69 Mastercam 11 04-08-2009 09:58 AM
Right Angle Head Programming ED209 G-Code Programing 5 03-10-2009 02:43 PM
Programing for Right Angle Head bkobernus Haas Mills 16 04-27-2007 05:31 PM
Programming for angle head--G18/G19 Dave L GibbsCAM 3 07-20-2006 10:33 PM
Right angle head programming Chris Baird Visual Mill 6 04-01-2006 02:09 PM
