Old 07-29-2010, 01:03 PM
johnhob is on a distinguished road
spindle bearingss
ok guys im in desprate need of chiron dz15w spindle bearing minus chiron uks 250% markup making a spindle set 4 grand can anybody help apparently the manufactrures of this bearing only do one run a year and thats ayear away so anybody who has them on the shelf will be greatly rewarded but not to great ok
Old 07-29-2010, 08:27 PM
Chiron dz15w: is that a machine model number? a bearing number? If it's a bearing number, I'm not familiar with it. ????
Dick Z
DZASTR
Old 07-30-2010, 01:50 PM
sdewolfe is on a distinguished road
I searched the term "chiron dz15w parts" I found that Rockwell Automation has a third party support division. They list the DZ15W as one of the machines they can support. It might be worth a try to contact them. They are international. It's a shame that Chiron can't get you spindle bearings quicker than that (or less expensive). If it comes down to it, you may need to pull the bearings to measure and match with another vendor. Most bearing supply companies will research the part for you if you bring them the bad bearings. Good luck and let us know how it turns out for you.
http://www.rockwellautomation.com/se...hirdparty.html
1992 VF2 Alarm 123 spindle Spindle Drive Fault dafowfidy Haas Mills 15 05-14-2012 01:32 PM
spindle motor and spindle control dont work customcncparts Milltronics 0 10-01-2009 02:08 PM
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 02:49 PM
Just had my spindle reground by Spindle Grinding Service! Edster Fadal 30 06-16-2006 10:48 PM
