Old 07-29-2010, 12:11 AM
zerodegreec's Avatar
zerodegreec is on a distinguished road
Milling x/y handle play
How much play is normal or acceptable when you change the direction of one of the table axis handles?
For example if I am turning my x axis clockwise and switch to counter clockwise the handle spins 0.076mm before the table moves
How I tested:
I setup my dial indicator up against the table and zeroed the reading. I then ran the table in the opposite direction and recorded the wheel indicator position before the table moved.
Old 07-29-2010, 05:45 AM
doorknob's Avatar
doorknob is on a distinguished road
That's much less backlash than what I am seeing on the Bridgeport mill that I'm using in the machining class that I'm taking - when I switch directions on the x-axis dial, the handle has to be turned by about 0.080" (which, if I've done my math correctly, is close to 2.0 mm) before the table begins to move the other way.
Luckily, with a DRO on the mill, I can ignore the backlash and pay attention only to the readout.
Need Help!- play in V bearings neomagik DIY-CNC Router Table Machines 8 03-27-2010 09:47 PM
Got to play some more with the R2V3 wcarrothers1 Bridgeport and Hardinge Mills 0 06-20-2007 11:57 AM
CNC kit ?(Plug n' Play) rhupin Open Source CNC Machine Designs 4 01-18-2007 01:51 PM
Plugged But Will Not Play! Oldmanandhistoy Computers and Networking 43 12-06-2006 05:24 PM
Want to see how those who buy some of you stuff play? weimedog CNCzone Club House 1 08-28-2006 06:54 PM
