Old 07-26-2010, 02:11 PM
beezerlm's Avatar
beezerlm is on a distinguished road
Heald (Cincinnati) ID grinder
Does anyone know a mechanic familiar with heald ID grinders? We have a hydraulic problem with ours and everyone we called so far has failed to fix it. Its a powerful machine we would like to use and the problem is probably simple we just can't find anyone who knows these machines.
Thanks in advance!
Brandon
Old 07-27-2010, 03:23 AM
SKENEY is on a distinguished road
Brandon what is the problem? I have a few friends that have rebuilt this type of grinder I may be able to get some information for you.
Regards
Old 07-27-2010, 06:15 AM
beezerlm's Avatar
Well, It started off with the hand wheel not engaging when switching out of automatic feed mode. There is a hydraulic line running to the handwheel that overpowers a spring to engage the gears. That appeared to have pressure but did not function properly. I have had 3 different hydraulic guys come out to look at it and they made the problem worse! Now the Table only moves in Rapid mode and does not feed in regular traverse mode. I have a manual for the machine, the model is "plain 271". It has a hydraulic diagram but it is not very detailed so it is hard to follow. This is a very nice, accurate machine we wish we could use. I just can't find anyone who knows how to fix it. We are located in Toledo OH. I would think there would be someone from the detroit area that would have worked on these things.
Thanks!
Brandon Bihn
Die Grinder Help Dave's_Not_Here Diemaking and Diecutting 4 03-21-2012 08:29 PM
Cincinnati tool & cutter grinder millman52 Toolgrinding & Toolgrinding Machines 5 03-21-2009 12:29 AM
NEED GRINDER Grinder Bob Toolgrinding & Toolgrinding Machines 3 01-13-2009 05:53 AM
looking for swisher grinder or swisher type of grinder JMG1 Toolgrinding & Toolgrinding Machines 1 09-04-2008 07:58 AM
Need Help!- need a manual for Heald plain 271 tjenkins007 Want To Buy...Need help! 0 03-20-2008 11:34 AM
