Old 07-23-2010, 10:00 PM
InventIt is on a distinguished road
Help with ID'ing this spindle and it's components
Hello, I bought this spindle cartridge off ebay a while ago. Plan is to use it in a homebuilt router/mill. It was expensive and I don't want to destroy it. So, not knowing anything about it can anyone help me by pointing out anything I should know?
I was told it is from a Kitamura Mycenter 0. Supposed to be a 15000 rpm unit, and has a bt30 taper. This seems to check out looking at the specs on the Kity site. A Mycenter 0 has a BT30 taper and can come with an optional 15000 rpm spindle. OK, so maybe this is true.
The questions I have about it:
What lubrication should I use if any? Is it an air/oil feed lube and is that what the hole in the mounting flange is for (with the red plug)? What is the hole in the side, near the center, that has a hex plug in it for? What is the notch in the aluminum part at the top where the draw bar pokes out used for if anything, maybe alignment during a tool change? Can I apply force to the draw bar and have that force held back by the bearings or is the flange under the aluminum part used for squeezing the draw bar between the part that sticks out and the flange therefore not putting excessive force on the bearings?
Lot of questions... Any help would be appreciated. Thanks
Name:	small copy-4329.jpg‎
ID:	111479   Click image for larger version
Name:	small copy-4328.jpg‎
ID:	111480   Click image for larger version
Name:	small copy-4331.jpg‎
ID:	111481   Click image for larger version
Name:	small copy-4330.jpg‎
Spindle Control Components - Help Please! blades Mini Lathe 2 05-21-2010 06:22 PM
Newbie- Techno Components dcms DIY-CNC Router Table Machines 0 05-12-2008 11:23 AM
DIY with quality components yohudi DIY-CNC Router Table Machines 66 01-26-2008 03:44 PM
7x Lathe, spindle drive components RotarySMP Mini Lathe 4 11-26-2005 03:08 AM
