Old 07-21-2010, 11:56 AM
Gpandm is on a distinguished road
Cool Need Help
I purchased a milling machine at an auction a couple of years ago. When I purchased it it wasn't under power but they said it had some problems. I powered it up and everything works but the table osclates x and y rapidly when you reset servos. I called tech support at Anilam and they thought it was a wiring issue or problems with the tachs.I checked the wiring and everything tested OK. I checked the tachs and they seem to be functioning fine.
The machine is older with westamp 30060-75 drive boards and with a newer Anilam 3000m controller. Not sure if anyone can help but any imput would be much appriciater.
Thanks James!
