Old 07-13-2010, 02:22 PM
Med-Pac is on a distinguished road
Red face Has anyone ever asked this before?
Hello there,
Been around here for years. This site has been very helpful to say the least. I was recently asked by a customer what the difference between inscription/engraving/etching was. I told him that they are basically the same, using different methods to get the same result. Was I right? Figured I'd check and make sure.
Thanks in advance,
Mike
Old 07-13-2010, 02:34 PM
Al_The_Man's Avatar
I have always understood that engraving is with a rotary tool, and etching is with acid?
Old 07-13-2010, 02:36 PM
Algirdas's Avatar
Algirdas is on a distinguished road
different technologies. Result is also different. It depends on point of view, on circumstances the question is asked. I would explain like this:
1. inscription is when non-specific tool slides through sensitive surface and leaves the track. Leather ornaments, for instance. You can make it by wooden tool, by roller pen, by special steel pen and result would be the same most cases. The material is deformed in work area.
2. engraving is kind of cutting. You use special tool and make chips. It is chisel for linear cut or rotary cutter - freza - for spindle work. The material is removed on tool trace.
3. etching is chemical reaction based material removing technique. Used mostly for metals.
You asked for it!!!!!!! CNCadmin CNCzone Site News and Contests 9 03-09-2008 06:23 PM
Asked the 4 Axis Milling weberluk BobCad-Cam 1 05-08-2006 05:08 PM
This May Have Been Asked Before noid CNC Plasma and Waterjet Machines 0 01-25-2005 07:33 PM
What's new you asked? wms OneCNC 11 06-24-2003 03:31 PM
