Old 07-12-2010, 09:23 AM
bkorte is on a distinguished road
FANUC 18T CONTROLLER G10 CODE
Can G10 command be used to temporarily change the workshift/work offset in an end-for-end turning/boring operation? If so how? Then is G10 or other G command used to reset original offset when repeating "A" side on next part?
Thank you
Old 07-12-2010, 05:11 PM
FrankCNC is on a distinguished road
18T Controller G10 Code
On my 15M I use, G91 G10 L2 P0 X*** Y*** Z*** to incrementally add to the existing external work offset and then at the end of the tool use G91 G10 L2 P0 X-*** Y-*** Z-*** to set the external work offset incrementally back to its original value.
i.e. G91 G10 L2 P0 Z-10. would subtract 10.mm from the External work offset moving the zero point in 10.mm.
& G91 G10 L2 P0 Z10. would add 10.mm back on to the External work offset moving the zero point back out 10.mm.
You might have to use W instead of Z and also not use G91 for the Lathe controller as the above example is for a Mill.
On the 15M the offsets can be viewed at parameter # 1220, possibly the same for a 18T.
Be sure to set G90 again after each G10 code in the program.
The same can be done for work offsets G54-G59 where G54 = P1, G55 = P2 etc.
This should all be the same for an 18T controller
Hope this helps.
Regards,
Frank.
Old 07-15-2010, 09:47 AM
Thanks for your help Frank!!
Need Help!- My Milling OKK with fanuc 6M can't recognize G-code & M-code nessei Fanuc 4 03-29-2011 08:39 AM
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Newbie Question - How to get the code into the controller? ktmrider Fanuc 6 12-17-2009 09:36 PM
g code controller Mut designer Servo Motors and Drives 10 11-24-2006 01:40 PM
Controller Code Snippets jhwatts OpenSource Software 3 10-10-2005 11:07 AM
