Old 07-11-2010, 05:18 PM
xclr82xtc is on a distinguished road
3 phase power in home shop?
ANyone have anyideas how to get 400v 3 phase into my home garage? i mean who do i talk to, how much $$ etc. I am the only one on my transformer if that matters..
Old 07-11-2010, 05:22 PM
ger21's Avatar
Pay your electric company lots of money.
Maybe someone else has a better way, though.
Old 07-11-2010, 05:38 PM
from what i have read on google, that seems like the only way. oh well..not tryin to buy the machine NOT to make money..and it cost money to make money
Old 07-11-2010, 06:06 PM
stevespo is on a distinguished road
I could definitely be wrong there, but I thought a friend had 440V/3PH power at his home shop. It involved some type of step up transformer and phase converter. I will give him a call and see what the story is.
Steve
Old 07-11-2010, 06:21 PM
a freind just told me its only a matter of paying a service charge and the line to have the other 2 phases ran from the transformer to the house. apparently each home (lot) only receives one of the 3 phases, and when you multiply your current power input x3...well, you get the idea. im gonna call tommorrow, ill see if i can run all the line and what not to save some money and just have the power company make the connections. If not, my freind and i just started a motorcycle shop, we will have to ask for some more square footage and up the lease.
Old 07-11-2010, 07:33 PM
bobsch's Avatar
bobsch is on a distinguished road
Most residential neighborhoods (at least around here) have only single phase available at the power pole.
If there's only one or two wires at the top between poles (not the drop to your house, that's always three wires), you've got single phase power and the power company will very likely tell you they won't change it out because it would involve re-wiring the entire neighborhood. At that point your only easy choice is a rotary phase converter like one of these: http://shop.ebay.com/?_from=R40&_trk...All-Categories
If the power poles in your neighborhood have three or four wires running between them, it's three phase and changing out the transformer will only cost you an arm and a leg.
Bob
"Bad decisions make good stories."
Old 07-11-2010, 07:39 PM
Al_The_Man's Avatar
Maybe in many other parts of the world, each residence is fed with one phase of a 3 phase transformer with star neutral.
Here in N.America you have a 1 phase 240 volt supply with a centre tap for 120v.
Most service companies will not entertain suppling 3 phase to a residence.
Old 07-11-2010, 07:45 PM
you guys sure arent very comforting. lol...ok so if i get a rotary converter, how do i ensure i have enough amperage when i step the 220 up to 440?
Old 07-11-2010, 07:50 PM
Al_The_Man's Avatar
What exactly is the nature of the machine you want 400 for?
Many machines have motors that will convert to 220, and most of the control runs off 120vac 1ph usually.
Old 07-11-2010, 07:52 PM
looks like the power line has 6 legs to pick from... i guess i will find out tommorrow wether i can get it. i would rather just go ahead and get it put in that have to worry about it later AFTER i buy a RPH..i dont plan on having one machine for long.
its for a hurco bmc 3017 15 horse spindle
  #11   Ban this user!
Old 07-11-2010, 07:54 PM
ihavenofish is on a distinguished road
i think rotary converters have to be matched rather precisely to the load. there are also digital phase converters, which i think are more versatile, but cost many thousands of dollars.
what are you wanting to run, how much power does it use?
  #12   Ban this user!
Old 07-11-2010, 07:55 PM
all the more reason to do it the right way..see above
1 phase Vs 3 Phase power what is the difference????? KustomKoncepts Commercial CNC Wood Routers 12 11-17-2007 10:34 PM
Farm/Home Shop lilguy General Metal Working Machines 7 08-02-2007 07:20 PM
Moving Shop 3 phase converter ?s conceptmachinin Phase Converters and VFD 23 07-26-2007 09:47 PM
Power Setup for Home Shop Ed from NY General Electronics Discussion 12 10-08-2006 05:52 PM
