Old 07-09-2010, 01:04 AM
zavateandu is on a distinguished road
LEADWELL VMC 25 with MELADS M50 controller
hi
anyone have the mechanical book of a leadwell vmc 25 with meldas m50 controller?
i have to chance the bearings on the spindel but i don't know the type of bearings so i need a spare parts book.
also i loose everytime the G54 seetings when i change program.
any help will be apreciated.
maybe could have only the spindel page from the book scanned?
many thanks!
Old 07-14-2010, 02:00 PM
EPTech's Avatar
EPTech is on a distinguished road
I have the exact same machine. I am not in my machine shop right now but I will be glad to help you. I will look in the spare parts list tomorrow (GMT+1).
I also have a question for you. Does your machine have the 4th (B) axis integrated?
Question to other members:
My machine has the B-axis on the control panel but there is no servo controller installed for it. Logically the machine reports an error if I try to move the B-axis. Would it be possible to attach an extra servo controller MDS-A-SVJ-10 in the control chain, adress it and assign it to the B-axis. I have a golden sun rotary table with a separate controller. The idea is to fully integrate this rotary table in the machine so I can do interpolation with the 4th axis. I need some amount of certainty before I buy a $1400,00
2nd hand servo drive. I could also try sniffing on the control chain and design some interface between the NC and the external controller. But there must be a faster way, right?
Kind greetings.
Old 07-15-2010, 12:36 AM
hi
thank you for u help
if u have a pdf file with spare parts i will apreciate if u can send it to me via email.
thank you again in advance.
HAVE A GOOD DAY!
GOOD LUCK!
PS:NO MY MACHINE HAS NOT 4 AXIS INTEGRATED BUT I CAN HELP U IF U HAVE QUESTIONS.
Old 07-16-2010, 06:04 AM
EPTech's Avatar
There are 2 sets of spindle bearings. Since you are taking apart the spindle assembly, I would change both. Each part number orders one set (2 bearings).
C01AA09110, Spindle Bearing (UPPER SET), 2MM9110WIDULFS660
C01AB09112, Spindle Bearing (LOWER SET), 2MM9112WIDUMFS660
I will send you a copy of the drawing and the part list later when I get home from my shop. I do not have the time to copy the whole book because it is 50 pages and the drawings fold open -> difficult to copy.
Kind greetings.
Old 07-16-2010, 12:50 PM
HI M8
Thank you for your help.
i understand, maybe only the page with the bearings will be enough for me.
thank you again for your help.
GOOD LUCK!
Old 07-21-2010, 02:24 PM
EPTech's Avatar
I have sent a pdf to your hotmail address. Good luck fixing the machine.
Need Help!- help with Leadwell MCV-OP prec-tech General Metal Working Machines 3 06-13-2011 12:34 AM
leadwell mcvo controller alarm monaro mike Fanuc 2 03-21-2008 06:38 AM
leadwell vmc 25-need help _pk_rasta_ General Metal Working Machines 1 12-22-2007 10:54 PM
Help! Servo controller problem on Leadwell VMC SRT Mike General Metal Working Machines 3 12-14-2007 07:16 AM
Leadwell VMC?????? Fudd General Metal Working Machines 6 02-13-2007 08:18 PM
