Old 07-07-2010, 04:16 PM
lukewarm is on a distinguished road
Rulon (PTFE) Experiences?
Has anyone used Rulon bearings in a CNC machine?
I've been doing a bit of research and Rulon sounds like a dandy material. Kinetic and static friction are very near the same (no slip-stop chatter) and the coefficient of friction is very low. Also it handles a huge amount of pressure and isn't subject to cold flow. I priced out some cold finished 2" shafting and it's very cheap (100$ for 6 feet) and the bearings themselves are a few dollars a piece. Anyone have any experience with Rulon or any other PTFE? I think it would be a good choice for my z-axis!
Old 07-07-2010, 04:29 PM
Rulon and other PTFE "plastics" have been used for years on sliding way surfaces on machine tools.
Can be "scraped" and "flaked" similar to traditional cast iron surfaces.
My experience with Rulon etc. has been very positive, especially on flat surfaces. I'm not familiar with it being used on round surfaces for sliding or rotating motion.
Dick Z
DZASTR
Old 07-07-2010, 06:10 PM
Thanks Richard! Do they compare well to roller type bearings friction-wise or should I consider them a bit less efficient (for my stepper sizing calculations).
Old 07-08-2010, 10:24 AM
The "plastic" way systems have less friction and stick-slip than plain metal slide surfaces. However, they have far more friction than ball or roller guide ways.
The plain ways whether "plastic" or metal, when properly sized, can carry more weight but at lower speeds.
It is, as usual, a trade-off. The manufacturers of rolling bearing type way systems usually publish the formula for force required to move a load. Generally this is in the tech sections of their on-line catalogs.
Dick Z
DZASTR
carbon filled ptfe piston rings? samco CNCzone Club House 5 03-01-2011 07:06 PM
Teflon ( PTFE ) Nut for CNC... Any reviews? Brenck Linear and Rotary Motion 4 06-07-2009 10:43 PM
Any other experiences with K2? adam dogg Commercial CNC Wood Routers 9 01-16-2007 09:42 AM
New Experiences Prosper Europe Club House 0 01-02-2007 03:46 PM
THK experiences vwdevotee Linear and Rotary Motion 6 12-23-2006 06:10 PM
