Old 07-01-2010, 03:50 AM
Nightwinter is on a distinguished road
Quick question
Hey guys,
Not a first time poster just forgot my last account details
My question is:
My Father has his own business and requires some plasma cutting work to be done for him, are we allowed to submit job listings on this website? or am i just missing the section? this could possibly make someone some good money as it would be a repeat order if the prices were right so i think it would be nice to share it out with the community. unfortunatly its UK only
Old 07-01-2010, 03:54 AM
Sorry ive just found the correct section
Old 07-01-2010, 11:33 PM
emann is on a distinguished road
can someone please tell me the correct feeds and speeds for a high performance drill to drill out 1010 material. .250dia self centering. Running on a solid A51 Makino. Everytime I run at 10K at 60fpm I still cant break the chip. Instead it heats up and turns the chip purple. ANythoughts to overcome this problem. Lots of coolant! Blazer. Solid setup its just the feeds and speeds that got me on this one. ANy help out there??
Old 07-03-2010, 01:26 PM
JimBoyce is on a distinguished road
0.2618*RPM*Diameter = SFM (Surface Feet per Minute or your fpm?)
0.2618*10,000*0.250 = 654.5 SFM way to fast
60 SFM is probably OK with 0.002 to 0.004 Feed Rate. Try 0.003 FR.
This is gummy material, which means chips are hard if not impossible to break. Lots of pull outs or pecks is the way to go. This is also not a common material for machining, so use caution on provided recommended feeds and speeds, they have not been tested that much. Also keep in mind expensive tools do not work well on every material, regular good quality drills may work better. Good luck.
Quick G12.1 Question (L20) Ovrclck350 CNC Swiss Screw Machines 5 04-28-2010 01:26 PM
Newbie- Quick Question? littlebrewman Mastercam 3 12-05-2009 03:55 AM
New here, quick question 2T on TC-2 RonRoy2004 G-Code Programing 2 11-06-2005 09:16 PM
really quick question: bigal General Electronics Discussion 1 06-21-2005 07:39 PM
Quick V18 Question Edster BobCad-Cam 3 12-13-2004 09:53 AM
