Old 05-27-2005, 02:13 AM
bobcor's Avatar
bobcor is on a distinguished road
Problem Tapping Stainless
I am having trouble tapping stainless steel (400 series). I have tried several
things and now using a coated through tap in my blind holes as these seem
to be the only ones that don't break. What I was wondering is, is how do i tell
if the gain ect. is set properly on my spindle drive as I do not understand the
set up info at fagor. I use a fagor 8055 control with ac fagor drives and spindle orientation.? any help appreciated.
Old 05-27-2005, 08:54 AM
DAB_Design is on a distinguished road
Why type of tapping oil/fluid are you using? For stainless, we use MollyDee.
Dustin B.
I hear and I forget.
I see and I remember.
I do and I understand.
Old 05-27-2005, 11:51 AM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
Tapping stainless is a beeaatch! weve had the tool companys come in a set us up with their super wounderfull unobtainium taps, they seam to work great until the tooling guys leave the building!
After all the taps weve tried in stainless what ended up working the most consistantly was the basic 2 flute spiral point tap Uncoated (made for aluminum) with MOLYDEE.
we were doing 250 holes in each plate to the tune of 50 to 100 plates. We could get almost 3 plates before the tap broke but we changed the tap at each plate. (seamed a no brainer $4.00 tap vs as 500.00 plate, cost in time for repair was figured at around an hour) of course this was a 6-32 tap. So your app. might be different.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Old 05-27-2005, 02:36 PM
MILLMANM's Avatar
MILLMANM is on a distinguished road
Moly dee seams to be used alot , we have also started peck tapping
useing increasing z values after the g tap cycle
but this is for 3/8-16 roll from tap in 316l
good luck
IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH
Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust.
Old 05-27-2005, 06:19 PM
bobcor's Avatar
how do you peck-tap?
Old 05-28-2005, 09:44 AM
Basically program it to tap the same hole several times using different depths.
G85 X1.0 Y1.0 Z-.625 F9.9 R0
G85 X1.0 Y1.0 Z-1.25 F9.9 R0
G85 X1.0 Y1.0 Z-1.90 F9.9 R0
G85 is actually for boring/reaming - as we use tap-a-matics alot - but you get the idea
Dustin B.
Old 05-29-2005, 08:43 PM
MILLMANM's Avatar
yes Dab has it right , sorry for the late reply, working the weekend shift,
like a drill cycle, a tap cycle is also modal, untill a g80 is called so adding z values after the can cycle wil repeat at each value
Old 05-29-2005, 09:27 PM
HuFlungDung's Avatar
Moderator
You might try nudging the tap drill size a bit larger, maybe trying for 60% thread instead of 70%. If you can get approval for this, it takes quite a bit of load off the tap.
I like the Ridgid NuClear thread cutting oil for heavy duty work like this. I've not tried this MolyDee stuff, though.
Keep the rpms about 25% slower than you would for tapping steel. Stainless does not transmit heat very well.
Old 05-31-2005, 05:54 PM
imwllc is on a distinguished road
i tap a lot of stainless, and i have had to do a lot of blind holes and have had the best luck using molydee and a slow spiral flute tap with a 3 thread chamfer or lead, and the cutting face hook or rake angle has to be 10-15 degrees. in deeper hole applications greenfield has sold me taps with a interrupted of releived thread and they have worked great. all the taps i buy are either greenfield or emuge, nobody else has shown me a better tap than these two companys
Old 05-31-2005, 05:55 PM
also i usually run between 20 and 40 sfm when i tap, my parts are usually 60-70% thread
  #11   Ban this user!
Old 05-31-2005, 10:08 PM
take a cut is on a distinguished road
i also have had the best luck with spiral flute taps and found osg to be the best choice per part from a cost perspective 316 ss this was
  #12   Ban this user!
Old 05-31-2005, 10:49 PM
ghyman's Avatar
ghyman is on a distinguished road
My nifty little tapping guide says 10-15 SFpM for 400 stainless.
A place I used to work had a different slant on things...
Threads per Inch times 10 equals RPM. (24 TPI = 240 rpm)
Their logic behind this was pretty convincing... The pitch determines the actual size (surface area) of the thread; a smaller thread (higher tpi) can run faster than a larger thread (lower tpi).
This really suprised me at how well it worked, but I can't remember for certain if it was 300 or 400 stainless.
But the nifty tapping guide has never failed me!
Okuma LC-20 Threading problem Gunner Machine Problems, Solutions , Wireless DNC, serial port 13 12-13-2011 11:11 PM
CNC gantry Machine shows problem Alex S.A Machine Problems, Solutions , Wireless DNC, serial port 15 04-25-2005 04:02 PM
tapping 303 stainless bobcor General Metalwork Discussion 8 03-28-2005 05:58 PM
Tapping MPE racing General CAM Discussion 9 11-06-2004 01:42 PM
Fadal VMC4020A axis problem cwww Machine Problems, Solutions , Wireless DNC, serial port 16 12-02-2003 12:07 AM
