  #13   Ban this user!
Old 06-01-2005, 08:37 AM
DAB_Design is on a distinguished road
ghyman, we use the same method. Every now and then they (the programmers) feel like mixing things up and running the taps at a percentage of the x10 rule (slower or faster depending on material).
The best thing about that method, is that no matter what size tap, the feedrate is always the same. 10.0ipm. For some reason though, we always use 9.9 ipm.
In 95% of our hard metal (SS and Titanium), and sizes of 3/8" and over we use form taps.
Dustin B.
I hear and I forget.
I see and I remember.
I do and I understand.
  #14   Ban this user!
Old 06-01-2005, 08:34 PM
ghyman's Avatar
ghyman is on a distinguished road
The 9.9 IPM is probably to allow the use of a compressable tap driver (rather than a solid driver.) By running the feedrate slower, it allows the tap to "find it's own best way" into and out of the part, instead of having the machine just JAM it into the hole. Tapping is a brutal operation, every little bit of assistance helps!
  #15   Ban this user!
Old 06-05-2005, 08:46 AM
BillPSu is on a distinguished road
Increasing the tap drill size will help. Drilling the tap drill hole deeper or through will increase the chip clearance below the tap and allow you to use a spiral point tap. If you cannot do any of these get bottoming heavy duty spiral flute tap. I've never tried slow spiral versus fast spiral taps. Heavy sulfurized cutting oils has always been the best tapping lubricant but in today's "clean" world it is not considered acceptable. There are many different lubricants which can do the job.
  #16   Ban this user!
Old 04-17-2008, 11:43 AM
TODDCOOPER is on a distinguished road
try express taps and moly dee as cutting fluid. express taps require a larger tap drill.
  #17   Ban this user!
Old 04-21-2008, 02:35 PM
ParkerMillguy is on a distinguished road
Peck-Tapping
Originally Posted by bobcor View Post
how do you peck-tap?
Depending on your control, you can usually put a "Q" on your G84 line. Q=incremental depth of peck until z depth is reached.
Okuma LC-20 Threading problem Gunner Machine Problems, Solutions , Wireless DNC, serial port 13 12-13-2011 10:11 PM
CNC gantry Machine shows problem Alex S.A Machine Problems, Solutions , Wireless DNC, serial port 15 04-25-2005 03:02 PM
tapping 303 stainless bobcor General Metalwork Discussion 8 03-28-2005 04:58 PM
Tapping MPE racing General CAM Discussion 9 11-06-2004 12:42 PM
Fadal VMC4020A axis problem cwww Machine Problems, Solutions , Wireless DNC, serial port 16 12-01-2003 11:07 PM
