Old 06-30-2010, 08:12 AM
digsrus is on a distinguished road
220 volt fans for Enshu machining center
I have a requirement for a couple of 5 inch square cooling fans for an older Enshu machining center. They look pretty standard, but unfortunately require 220 volts. Enshu now has a policy that requires a $750 fee to register used machines before any replacement parts may be purchased from them. So buying from Enshu is a last resort solution based on principle alone.
The fans are made by Tobishi pn# S4556m. I have only been able to locate them from a factory in Korea but the shipping cost from DHL was quoted as $525! I probably can kluge together a solution with more easily available fans, but I would like to have a similar replacement if possible.
Any help in this matter is welcome.
Thanks.
Old 06-30-2010, 08:27 AM
mactec54 is on a distinguished road
digsrus
You can get your axial fans at almost any good electrial supply Granger / Digikey / Newark Etc & even you may find the one that will do you on Ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...=263602_263622
Mactec54
Old 06-30-2010, 09:35 AM
The ebay fan was not quite the right size, but I was able to come up with a suitable replacement at Digikey. Price? $24 ea! CNCZone FTW!
Old 06-30-2010, 10:01 AM
Al_The_Man's Avatar
One thing to watch for when replacing fans is if they have rotation detection on them that shuts the machine down.
If they have three conductors to the fan, they could be this type.
Old 07-01-2010, 07:57 AM
M_Saint is on a distinguished road
The fans you are trying to replace are 119MMX38MM
Papst makes a fan with those dimensions just google part# p4850n-papst
And as stated by someone else many times I also just adapt some fans from Grainger or McMastercar Both of them stock 120mm 220v fans that can be modified to fit your machine.
okk MVC410 machining center cs_sas General Metal Working Machines 2 08-21-2007 04:14 PM
new to cnc machining center BruceinOZ CNC Machining Centers 6 08-11-2007 01:25 PM
HOW BIG IS YOUR CNC Machining Center? boxxer_boy CNC Machining Centers 5 04-10-2007 05:31 AM
D&M 4 Machining Center bill south General Metal Working Machines 0 07-17-2006 05:21 AM
New Machining Center porsche1220 CNC Machining Centers 0 04-27-2006 06:34 PM
