Old 06-24-2010, 03:51 PM
cedarpeaks is on a distinguished road
Leadwell X backlash
I have a circa 1996 Leadwell 1300mcv. In the X axis I have .03 backlash. I have discovered the same amount of play (.030) in the outer/inner collar assembly. It appears that the inner collar is .030 wider than step in outer collar, thus leading me to believe there has been wear. However, if the inner collar and outer collar step are equal, will the lock nut(far right, don't know if this is proper name) rub against the outer collar. Thrust bearings appear fine. Any recommendations?
Backlash or motor tuning problem? How do I test for backlash? Brian Queen Mach Mill 8 03-10-2008 03:35 PM
leadwell vmc 25-need help _pk_rasta_ General Metal Working Machines 1 12-22-2007 10:54 PM
leadwell mcv-550 roadworriar General CNC (Mill and Lathe) Control Software (NC) 5 10-22-2007 04:34 PM
Leadwell VMC?????? Fudd General Metal Working Machines 6 02-13-2007 08:18 PM
Servo idea - elimated backlash - zero backlash ! synthetiklone Linear and Rotary Motion 6 12-06-2006 01:35 PM
