Old 06-24-2010, 05:32 AM
cro-magnum is on a distinguished road
Tri-onics mill help?
I have searched here and other sites w/out much luck
The company I work for picked up a handyman 2.5D Tri-onics mill ($800). I managed to fumble through its awkward DRO/computer to check all axis's. Seems to work well and will make for a great machine (for what they need) if they update the comp.
For now what I am looking for is a couple of pointers on how to program and to find a manual. I have programed a couple blocks to check the axis's, do you somehow link these block to form a program? I can make it move to position, circle, drill, and some other things but never two things one after another. I really need to talk them into some new software.
For those of you that have not seen or used a machine like this... It will not accept G code.
Thanks for reading
Travis
Mini mill X2 $359 at harbor freight - returning micro mill Micro Milling Benchtop Machines 18 12-15-2009 01:10 PM
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-11-2009 11:11 PM
RFQ - milling work on 1/4" wide tool steel - may need azis mill or right-angle mill pendentive Employment Opportunity 7 01-21-2007 07:56 PM
