Old 06-23-2010, 10:30 PM
cob cob is offline
cob is on a distinguished road
can anyone help
hello to AGAIN.
I am trying to find someone around the bay area (california) who has hooked up a 3 phaze motor in there garage.
I am trying to make a lathe run if there is some outhere that knows how to do this. i would not mind paying you for your work.
thanks.
Old 06-23-2010, 11:26 PM
jalessi's Avatar
jalessi is on a distinguished road
Question
Cob,
What horsepower is the motor?
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 06-24-2010, 08:22 AM
Al_The_Man's Avatar
Originally Posted by jalessi View Post
Cob,
Jeff...
See post... http://www.cnczone.com/forums/showthread.php?t=106926
Old 06-24-2010, 12:00 PM
jalessi's Avatar
Post
COB,
Drives Warehouse has a 7.5 horsepower 220 volt single phase VFD Polyspede model PC1-75. It will handle a 7.5 horse motor without being de-rated, we use them all the time.
http://stores.ebay.com/driveswarehouse
http://www.polyspede.com/pc1_series.html
Al The Man gave you the heads up in the other post, his direction is golden!
Jeff...
Old 06-24-2010, 11:23 PM
cob cob is offline
COB,
Jeff...
thanks for the info.
but here is my question and maybe you can answer it
yes that is what i would like to buy and set it up on my machine know how big of a breaker do i need for this and also what do you mean buy no being de-rated
thank you guys.
I getting closer.
Old 06-25-2010, 01:44 AM
jalessi's Avatar
Post
COB,
For 1-phase drives, the current rating of the breaker should be 2 times maximum input current rating.
The drive input rating is 53.9 amps, I would use a 100 amp breaker.
The drive is rated at 7.5 horse motor when using 220 single phase so you do not need to purchase a oversize VFD.
Jeff...
