Old 06-21-2010, 09:01 PM
Goldhunter_2 is on a distinguished road
Question HELP comprehending reversible motor wiring
HELP comprehending reversible motor wiring. I have always been happy with the mill but tonight I decided I needed to be able to bore out something when I realized I needed the opposite rotation of the boring head
ok I have wired stuff before even though this set of question make me sound incompetent
my old kempsmith mill was converted form horizontal to a vertical (probably before I was born) it has a reversible switch but only works one direction. The current motor I assume is one direction I have another 1.5hp motor I got form a friend that is on my air compressor ........I think it is a reversible (two way) motor but not sure how to tell
also is the wiring done normal to the motor and switched at switch or vs versa ?
hopefully one of ya'll can educate me so I can get this fixed tomorrow
Old 06-21-2010, 09:14 PM
Al_The_Man's Avatar
The type of motor is needed in order to offer any information.
I assume the motors in question are 1 phase induction motors? If so you need the start winding and run winding terminations brought out to the terminal box, then continued to the reverser.
In a single direction motor, one end of each winding is connected internally and cannot be reversed easily.
Old 06-21-2010, 09:50 PM
yes the motors are defiantly single phase 110v motors , the one on the mill part of one sticker is unreadable and the other sticker just say "AOS" on the extra motor I have on the air compressor it is a "marathon" and does mention switching CCW to reverse rotation . my switch on the mill is a Square D type that's actual the only picture that came out half way viewable
I tried to get some pictures but only have a camera phone and its night time right now
Name:	R Image0-8.jpeg‎
ID:	109560   Click image for larger version
Name:	reversible power switch.jpeg‎
Old 06-22-2010, 05:43 AM
icecreamjones is on a distinguished road
Do you know if it is a capacitor start motor? The motor I use is off an air compressor and it's easy to reverse (capacitor start). Need a better pic of the label.
Old 06-22-2010, 06:34 AM
The motor on the mill has two capacitors so does the motor i put on the air compressor (it is not original motor)
I'll try to get some better pictures today of the labels
Old 06-22-2010, 08:03 AM
Al_The_Man's Avatar
One will be a run cap and the other the start cap, you can swap either the start winding or the run winding to change direction, in some cases the run winding is easiest.
Old 06-22-2010, 06:50 PM
ok these pictures are a little better but can't get one to come out of the motor on the mill now but the marathon is the one I think is reversible but all the wiring in there has me confused bigtime
here are a few pictures hopefully there readable, the Marathon motor has two stickers one is wiring diagrams talks about swapping black wire expect there four black wires inside
Name:	Motor sticker Marathon 2.JPG‎
ID:	109615   Click image for larger version
Name:	Motor sticker marathon 1.JPG‎
ID:	109616   Click image for larger version
Name:	Motor Marthon wireing box.JPG‎
ID:	109617   Click image for larger version
Name:	Motor currently on mill .JPG‎
Name:	motor two way stwich on mill.JPG‎
Old 06-22-2010, 08:13 PM
Al_The_Man's Avatar
There should be three together either black white orange or black white yellow depending on the current voltage it is wired for.
If you have three like that, it should identify the black to reverse with the red?
Need Help!- AC motor wiring dan pines General Electronics Discussion 12 12-18-2009 05:37 AM
Need Help with Magnetic reversible Contactor Chris64 General Electronics Discussion 12 12-23-2007 02:54 PM
motor wiring cueshark General Electronics Discussion 2 06-12-2007 10:25 PM
Can anyone help me with the wiring of the motor? Darc Stepper Motors and Drives 8 08-16-2006 09:57 PM
Motor wiring again (sorry Al) kong General Electronics Discussion 14 06-10-2005 01:49 PM
