Old 06-21-2010, 10:54 AM
greenchair is on a distinguished road
Hermle Profibus Hardware Error
Hello, has anyone has this error on their 5-axis Hermle / Heidenhain machine?
Profibus Hardware Error.
There amazingly does not seem to be anyway whatsoever to narrow down this issue.
I have checked all the communication lines to make sure the connections are tight and that the wires are not sitting near high voltage lines but it still errors.
It seems to error when the machine is just sitting at idle.
thanks in advance
g
Old 06-21-2010, 12:52 PM
andyb4 is on a distinguished road
Good start with the connections. I believe that the cables to the profibus run through a cable carrier. You may want to try and run a 'spare' cable from point A to point B without going through the carrier to see if the cable has worn in the carrier. You may also want to check the switches connected to the unit. You can check the I/O screen on the control. You can also look at the prox. switches themselves, they each have an indicator light on them that should be lit constantly while the switch is made. If it is only while sitting the switches that indicate the current position will be the ones you should be looking at.
810 M on a Hermle 721 cygnetron Siemens Sinumerik CNC controls 0 01-24-2010 11:44 AM
Hardware Limit Error jhwatts LinuxCNC (formerly EMC2) 9 07-22-2009 10:33 AM
ECAS 20 - Profibus-DP: fault of drive ChristianK CNC Swiss Screw Machines 1 07-21-2009 03:43 PM
Does any one have a Hermle UWF 1000 Repair_man General CNC (Mill and Lathe) Control Software (NC) 0 10-24-2007 07:22 PM
Cable layout for 9 Pin D-Profibus interface interflexo Computers and Networking 1 11-29-2006 02:03 PM
