Old 06-19-2010, 08:03 PM
Magnum164 is on a distinguished road
Grizzly 0602
Just bought this machine and setting it up. At the moment I have not been able to remove the chuck so I can clean/oil the threads. I have used the suggestion of crevicereamer of holding the spanner nuts on the back with no luck, they simply unscrewed. I simply can't even budge that chuck loose.
Old 06-19-2010, 09:09 PM
alexander m is on a distinguished road
I had this same problem with my taig lathe, the problem was that some brass chips were in the thread and locking it. I loosened it by locking the spindle with a steel wrench (I brook the aluminum wrench) then by pounding the chuck with a rubber hammer. But before you do this, check if there is a locking set screw behind the chuck.
Old 06-19-2010, 09:25 PM
Since this is a new machine, I imagine it is that red junk that has sealed the threads. Both holding clamps are removed. There really is no where to wedge a wrench that I can.
Old 06-19-2010, 09:44 PM
I can think of two other ways to get it off but there are a little damaging. First by placing a peace of wood between the chuck jaw and the bed so that the chuck can not turn clock wise and turn the motor on backwards at the lowest speed. or drill a hole thru the spindle in the section between the barring and insert a screwdriver in the hole to lock the spindle.
Old 06-20-2010, 01:26 PM
Yes.. Those thoughts crossed my mind, but looking for non-destructive ideas. But thanks for the ideas.
I do know the red gunk cleans up nice with WD-40, I clean all of my machines with it. So I removed the chuck from the backplate and have been spaying some liquid-wrench type oil in there. With the chuck removed I can actually spray directly into the threads. Then I lightly wrap on the backplate with a dead blow hammer. Works on some tough car parts
I will order a spanner wrench tonight and maybe be able to grab the spindle better and place the chuck back on and hopefully just a little effort will break it up.
Old 06-20-2010, 03:27 PM
Got it!
Found a spanner wrench that would grab the spindle hole where one of the key arms goes in for loosening and wedged it behind a SHCS holding the rear splash guard on. The grabbed the chuck jaws with a crescent wrench a couple of blows with a dead blow hammer and off it came.. Nothing damaged, no harm.
Old 06-22-2010, 02:19 PM
photomankc is on a distinguished road
I got it off in a similar way but I had to get a stack of wood/metal that would support a 5/16 section of rod horizontal, right at the mouth of one of the spanner holes. I found that if there was a gap I could obtain enough leverage to simply bend the rod, shoot the stack across the room, scrape my knuckles, and the chuck still wouldn't budge. Getting the rod stuck out horizontal and supported right at the mouth of that spanner hole in the spindle was the ticket. I cursed that thing for two days trying to break it loose.
Glad you got it loose without tearing up anything.
Old 06-22-2010, 04:04 PM
Oh I still have the busted knuckles at least
Old 06-22-2010, 07:27 PM
Grizzly 0602
Well yeah. I didn't mean your body. That stuff grows back. It's the big chuncks of cast iron you gotta protect right?
CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
Old 06-22-2010, 07:45 PM
Yea, in the confusion I sprayed my knuckles with WD40 to prevent them from rusting..
And just in case someone finds this post later and wants a visual aid...
GRIZZLY X3 OR HF X3? cornbinder23 Benchtop Machines 46 12-24-2009 12:12 AM
X3 at grizzly JFettig Benchtop Machines 8 11-08-2008 06:42 AM
X3 HF vs. X3 Grizzly Kalvin Benchtop Machines 2 10-26-2008 04:16 PM
Any opinions on the Grizzly g4016 lathe or other Grizzly lathes? DublD General Metal Working Machines 3 11-26-2006 12:23 PM
The Grizzly and the Hen Metal_twister Benchtop Machines 20 10-26-2006 07:50 PM
