Old 06-19-2010, 05:53 PM
randyjaco is on a distinguished road
Help with a VFD Please!
Hi All,
I am new to the forum and could use some information on a VFD. My electronics knowledge is basic.
I have just purchased a Huanyang HY02D223B VFD of EBay and am having some problems. What I am trying to do is set this up to my 3 phase Bridgeport clone. I am just trying to use this to power my mill. I have done something similar on a lathe and mill using TECO VFDs. This thing sure ain’t no TECO and may not work for my application.
This is what I would like to do: I would like to have a small, wired remote control with a on/ off switch , a forward/ reverse switch and a pot to control the speed mounted on the mill. Easy to do on my TECOs. I have wired up the Huanyang and it will run my mill from the VFD. The problem is that I have to manually input the frequency and other parameters and if I cut the power, all I have inputed is lost. The VFD doesn’t seem to have any memory. The manual I have is not very helpful and I am lost.
Any help would be appreciated.
TIA
Randy
Old 06-19-2010, 07:37 PM
mactec54 is on a distinguished road
randyjaco
I have put a PDF of your drive it is just like any other drive & everything is in the manual for you to set it up
When changing a parameters you have to save it for each change or it will just go back to the default all drives will do this
Mactec54
Old 06-20-2010, 08:21 PM
Thanks for responding Mac. That is the same manual I have, but my key pad is different.
The manual shows 8 buttons:
F/R
Up arrow
Program
Shift key
Down arrow
Enter
Run
Stop/Reset
My key pad has 8 buttons, but they are as follows (see attached file)
Run
Stop
Jog
Up arrow
Prgm
>> (2 arrows pointing right) possibly the shift key
Down arrow
Set
Maybe I am keying things in wrong. This is the sequence I have been putting in:
The VFD is on I press PRGM the display goes to Pd000. I press the Up Arrow until I reach Pd013. I then press SET. The display shows END. Then go on to the next parameter and repeat the process.
Is there something I am doing wrong?
Thanks again,
Randy
Name:	Manual page.jpg‎
