Old 06-14-2010, 10:32 AM
dmorton is on a distinguished road
newbie looking for cnc machine advice
Hello,
First post - hope I have the right forum.
Ive been looking for a smallish cnc machine to be used in making aluminum front panels and other parts from aluminum and plastic. Aluminum is the main material I will be working with.
At first, I considered making a machine myself, but with the limited tooling I have, its probably better to buy one initially, and then think about using the machine to upgrade or expand itself.
Anyway, after doing a whole lot of research, the High-Z S-720 from cnc-step.de and the BZT PF-750 from bzt-cnc.de are looking like they might be the right machines for me.
One of the requirements I have is transportability - the ability to be easily moved, possibly internationally, once or twice a year.
Ideally the machine I choose should be able to be partly disassembled for ease of transport. Looking at the High-Z and BZT machines, there doesnt appear to be any way to unbolt the gantry from the frame.
I guess I am looking for some feedback on what people think about disassembling and reassembling CNC machines such as the High-Z and BZT machines. Is it feasible? Will I need special tools to reassemble with correct alignment?
Im also looking for suggestions of other machines in the same price, size and weight range (~EUR3000, ~400x600x100mm working area, 30-50kg weight range).
Thanks in advance,
Damien
Old 07-06-2010, 08:27 AM
shadowvoice is on a distinguished road
High-Z 720 can be packed as it is in a trunk of regular passanger car. I have moved mine in Toyota Avensis and Skoda Octavia as well.
2. I wouldn't suggest You to disassemble frame of machine.
3. In general I have to admit that I simply love High-Z machine which proved to be rigid enough and very precise.
A super newbie needs advice on which machine bellec Benchtop Machines 9 07-11-2008 04:10 AM
newbie looking for advice shawnmor Stepper Motors and Drives 2 03-09-2008 09:14 AM
Newbie to CNC, could use some advice. Blacksunshine DIY-CNC Router Table Machines 1 09-13-2006 11:52 PM
Newbie needs advice! Roy E. Toler DIY-CNC Router Table Machines 0 12-17-2005 04:54 PM
Newbie advice concerning DNC nlh Machine Problems, Solutions , Wireless DNC, serial port 4 10-09-2005 10:32 PM
